Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.301, pp.300-335, 2016. ,
DOI : 10.1016/j.cma.2015.12.015
URL : https://hal.archives-ouvertes.fr/hal-01149225
Fluid???structure interaction and multi-body contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46, pp.45-463603, 2009. ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00542238
Convergence analysis of a projection semi-implicit coupling scheme for fluid???structure interaction problems, Numerische Mathematik, vol.96, issue.1, pp.721-767, 2010. ,
DOI : 10.1007/s00211-010-0311-x
URL : https://hal.archives-ouvertes.fr/hal-00860416
Splitting Methods Based on Algebraic Factorization for Fluid-Structure Interaction, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1778-1805, 2008. ,
DOI : 10.1137/070680497
An analysis of a new stable partitioned algorithm for FSI problems. Part II: Incompressible flow and structural shells, Journal of Computational Physics, vol.268, pp.399-416, 2014. ,
DOI : 10.1016/j.jcp.2014.03.004
A Nitsche extended finite element method for incompressible elasticity with discontinuous modulus of elasticity, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.41-44, pp.41-443352, 2009. ,
DOI : 10.1016/j.cma.2009.06.017
URL : https://hal.archives-ouvertes.fr/inria-00341737
FINITE ELEMENT APPROACH TO IMMERSED BOUNDARY METHOD WITH DIFFERENT FLUID AND SOLID DENSITIES, Mathematical Models and Methods in Applied Sciences, vol.21, issue.12, pp.2523-2550, 2011. ,
DOI : 10.1142/S0218202511005829
The Finite Element Immersed Boundary Method with Distributed Lagrange Multiplier, SIAM Journal on Numerical Analysis, vol.53, issue.6, pp.2584-2604, 2015. ,
DOI : 10.1137/140978399
A fictitious domain approach with distributed Lagrange multiplier for fluid-structure interactions, 2015. ,
On the Stabilization of Finite Element Approximations of the Stokes Equations, Efficient solutions of elliptic systems, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
Fluid???structure interaction in blood flow capturing non-zero longitudinal structure displacement, Journal of Computational Physics, vol.235, issue.0, pp.515-541, 2013. ,
DOI : 10.1016/j.jcp.2012.08.033
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
An unfitted Nitsche method for incompressible fluid???structure interaction using overlapping meshes, Computer Methods in Applied Mechanics and Engineering, vol.279, pp.497-514, 2014. ,
DOI : 10.1016/j.cma.2014.07.007
URL : https://hal.archives-ouvertes.fr/hal-00918272
Fictitious domain finite element methods using cut elements: II. A stabilized Nitsche method, Applied Numerical Mathematics, vol.62, issue.4, pp.328-341, 2012. ,
DOI : 10.1016/j.apnum.2011.01.008
Projection Schemes for Fluid Flows through a Porous Interface, SIAM Journal on Scientific Computing, vol.33, issue.2, pp.541-564, 2011. ,
DOI : 10.1137/100788124
URL : https://hal.archives-ouvertes.fr/inria-00462103
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201750, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/hal-00701780
Analysis of a linear fluid-structure interaction problem, Discrete Contin. Dyn. Syst, vol.9, issue.3, pp.633-650, 2003. ,
Semidiscrete Finite Element Approximations of a Linear Fluid-Structure Interaction Problem, SIAM Journal on Numerical Analysis, vol.42, issue.1, pp.1-29, 2004. ,
DOI : 10.1137/S0036142903408654
Theory and practice of finite elements, 2004. ,
DOI : 10.1007/978-1-4757-4355-5
Effect of baffles on a partially filled cubic tank: Numerical simulation and experimental validation, Evans. Partial Differential Equations. Graduate studies in mathematics, pp.3-4198, 2009. ,
DOI : 10.1016/j.compstruc.2008.10.008
Convergence and error analysis for a class of splitting schemes in incompressible fluid???structure interaction, IMA Journal of Numerical Analysis, vol.36, issue.4, 2015. ,
DOI : 10.1093/imanum/drv055
Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: Stability analysis and numerics, International Journal for Numerical Methods in Engineering, vol.38, issue.6-7, pp.199-229, 2015. ,
DOI : 10.1002/nme.4785
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
Splitting schemes for incompressible fluid/thin-walled structure interaction with unfitted meshes, Comptes Rendus Mathematique, vol.353, issue.7, pp.647-652, 2015. ,
DOI : 10.1016/j.crma.2015.04.003
Fully decoupled time-marching schemes for incompressible fluid/thin-walled structure interaction, Journal of Computational Physics, vol.297, pp.156-181, 2015. ,
DOI : 10.1016/j.jcp.2015.05.009
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.566-593, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2007. ,
DOI : 10.1016/j.cma.2006.09.002
An eXtended Finite Element Method/Lagrange multiplier based approach for fluid???structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201699, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
An unfitted finite element method, based on Nitsche???s method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.47-48, pp.47-485537, 2002. ,
DOI : 10.1016/S0045-7825(02)00524-8
URL : https://hal.archives-ouvertes.fr/hal-01352903
New development in freefem++, Journal of Numerical Mathematics, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
Fluid-Structure Interaction in Internal Physiological Flows, Annual Review of Fluid Mechanics, vol.43, issue.1, pp.141-162, 2011. ,
DOI : 10.1146/annurev-fluid-122109-160703
Finite-Element Approximation of the Nonstationary Navier???Stokes Problem. Part IV: Error Analysis for Second-Order Time Discretization, SIAM Journal on Numerical Analysis, vol.27, issue.2, pp.353-384, 1990. ,
DOI : 10.1137/0727022
Nitsche???s method for general boundary conditions, Mathematics of Computation, vol.78, issue.267, pp.1353-1374, 2009. ,
DOI : 10.1090/S0025-5718-08-02183-2
An immersogeometric variational framework for fluid???structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.1005-1053, 2015. ,
DOI : 10.1016/j.cma.2014.10.040
Coupling schemes for the FSI forward prediction challenge: Comparative study and validation, International Journal for Numerical Methods in Biomedical Engineering, vol.301, issue.45-46 ,
URL : https://hal.archives-ouvertes.fr/hal-01239931
Numerical analysis of a linearised fluid-structure interaction problem, Numerische Mathematik, vol.87, issue.2, pp.317-354, 2000. ,
DOI : 10.1007/s002110000183
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
An Eulerian???Lagrangian method for fluid???structure interaction based on level sets, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.17-182070, 2006. ,
DOI : 10.1016/j.cma.2005.02.025
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, pp.339-377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
Kinematic splitting algorithm for fluid???structure interaction in hemodynamics, Computer Methods in Applied Mechanics and Engineering, vol.265, issue.1, pp.83-106, 2013. ,
DOI : 10.1016/j.cma.2013.05.025
Efficient Implementation of Finite Element Methods on Nonmatching and Overlapping Meshes in Three Dimensions, SIAM Journal on Scientific Computing, vol.35, issue.1, pp.23-47, 2013. ,
DOI : 10.1137/11085949X
Unconditionally stable discretizations of the immersed boundary equations, Journal of Computational Physics, vol.222, issue.2, pp.702-719, 2007. ,
DOI : 10.1016/j.jcp.2006.08.004
Fluid-structure interactions: cross-flowinduced instabilities, 2011. ,
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
Computational hydrodynamics of capsules and biological cells, CRC Mathematical and Computational Biology, vol.20103131, 2010. ,
DOI : 10.1201/EBK1439820056
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-983, 2007. ,
DOI : 10.1142/S0218202507002170
LLM and X-FEM based interface modeling of fluid???thin structure interactions on a non-interface-fitted mesh, Computational Mechanics, vol.408, issue.EM3, pp.319-332, 2011. ,
DOI : 10.1007/s00466-011-0600-y
Computational Methods for Parachute Fluid???Structure Interactions, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.125-169021206, 2009. ,
DOI : 10.1007/s11831-012-9070-4
The enriched space???time finite element method (EST) for simultaneous solution of fluid???structure interaction, International Journal for Numerical Methods in Engineering, vol.90, issue.3, pp.305-334, 2008. ,
DOI : 10.1002/nme.2258
URL : https://hal.archives-ouvertes.fr/hal-01371129
