New interface
Journal articles
Splitting schemes and unfitted mesh methods for the coupling of an incompressible fluid with a thin-walled structure
Miguel Angel Fernández 1, * Mikel Landajuela 1
* Corresponding author
1 COMMEDIA - COmputational Mathematics for bio-MEDIcal Applications
Inria de Paris, LJLL (UMR_7598) - Laboratoire Jacques-Louis Lions
Abstract : Two unfitted mesh methods for a linear incompressible fluid/thin-walled structure interaction problem are introduced and analyzed. The spatial discretization is based on different variants of Nitsche's method with cut elements. The degree of fluid-solid splitting (semi-implicit or explicit) is given by the order in which the space and time discretizations are performed.The a priori stability and error analysis shows that strong coupling is avoided without compromising stability and accuracy. Numerical experiments in a benchmark illustrate the accuracy of the different methods proposed.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01309462
Contributor : Miguel Angel Fernández Connect in order to contact the contributor
Submitted on : Sunday, May 3, 2020 - 7:46:06 PM
Last modification on : Friday, August 5, 2022 - 12:02:00 PM
File
paper.pdf
Identifiers
Citation
Miguel Angel Fernández, Mikel Landajuela. Splitting schemes and unfitted mesh methods for the coupling of an incompressible fluid with a thin-walled structure. IMA Journal of Numerical Analysis, 2020, 40 (2), pp.1407-1453. ⟨10.1093/imanum/dry098⟩. ⟨hal-01309462v3⟩
Share
Metrics
Record views
454
Files downloads
393
