Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures, Comput. Methods Appl. Mech. Engrg, vol.301, pp.300-335, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01149225
Convergence analysis of a projection semi-implicit coupling scheme for fluid-structure interaction problems, Numer. Math, vol.116, pp.721-767, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00406493
Splitting methods based on algebraic factorization for fluid-structure interaction, SIAM J. Sci. Comput, vol.30, pp.1778-1805, 2008. ,
A Nitsche extended finite element method for incompressible elasticity with discontinuous modulus of elasticity, Comput. Methods Appl. Mech. Engrg, vol.198, pp.3352-3360, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00437190
Numerical stability of the finite element immersed boundary method, Math. Models Methods Appl. Sci, vol.17, pp.1479-1505, 2007. ,
Finite element approach to immersed boundary method with different fluid and solid densities, Math. Models Methods Appl. Sci, vol.21, pp.2523-2550, 2011. ,
The finite element immersed boundary method with distributed Lagrange multiplier, SIAM J. Numer. Anal, vol.53, pp.2584-2604, 2015. ,
A fictitious domain approach with lagrange multiplier for fluidstructure interactions, Numer. Math, vol.135, pp.711-732, 2017. ,
On the stabilization of finite element approximations of the Stokes equations. Efficient solutions of elliptic systems, Notes Numer. Fluid Mech, vol.10, pp.11-19, 1984. ,
Fluid-structure interaction in blood flow capturing non-zero longitudinal structure displacement, J. Comp. Phys, vol.235, pp.515-541, 2013. ,
Stability and convergence analysis of the extensions of the kinematically coupled scheme for the fluid-structure interaction, SIAM J. Numer. Anal, vol.54, pp.3032-3061, 2016. ,
An unfitted Nitsche method for incompressible fluid-structure interaction using overlapping meshes, Comput. Methods Appl. Mech. Engrg, vol.279, pp.497-514, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00918272
Fictitious domain finite element methods using cut elements: II. A stabilized Nitsche method, Applied Numerical Mathematics, vol.62, pp.328-341, 2012. ,
Added-mass effect in the design of partitioned algorithms for fluid-structure problems, Comput. Methods Appl. Mech. Engrg, vol.194, pp.4506-4527, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00071499
Analysis of a linear fluid-structure interaction problem, Discrete Contin. Dyn. Syst, vol.9, pp.633-650, 2003. ,
Semidiscrete finite element approximations of a linear fluid-structure interaction problem, SIAM J. Numer. Anal, vol.42, pp.1-29, 2004. ,
Theory and practice of finite elements, 2004. ,
Partial Differential Equations. Graduate studies in mathematics, 2010. ,
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, Int. J. Num. Meth. Engrg, vol.69, pp.794-821, 2007. ,
Incremental displacement-correction schemes for incompressible fluidstructure interaction: stability and convergence analysis, Numer. Math, vol.123, pp.21-65, 2013. ,
Splitting schemes for incompressible fluid/thin-walled structure interaction with unfitted meshes, Comptes Rendus Mathematique, vol.353, pp.647-652, 2015. ,
Convergence and error analysis for a class of splitting schemes in incompressible fluid-structure interaction, IMA J. Numer. Anal, vol.36, pp.1748-1782, 2016. ,
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Comput. Methods Appl. Mech. Engrg, vol.196, pp.1278-1293, 2007. ,
An extended finite element method/Lagrange multiplier based approach for fluid-structure interaction, Comput. Methods Appl. Mech. Engrg, vol.197, pp.1699-1714, 2008. ,
An unfitted finite element method, based on nitsche's method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, pp.5537-5552, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01352903
New development in FreeFem++, J. Numer. Math, vol.20, pp.251-265, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01476313
Finite-element approximation of the nonstationary Navier-Stokes problem. IV. Error analysis for second-order time discretization, SIAM J. Numer. Anal, vol.27, pp.353-384, 1990. ,
Nitsche's method for general boundary conditions, Math. Comp, vol.78, pp.1353-1374, 2009. ,
A stabilised immersed framework on hierarchical b-spline grids for fluid-flexible structure interaction with solid-solid contact, Comput. Methods Appl. Mech. Engrg, vol.335, pp.472-489, 2018. ,
A weak-coupling immersed boundary method for fluid-structure interaction with low density ratio of solid to fluid, J. Comput. Phys, vol.359, pp.296-311, 2018. ,
Numerical analysis of a linearised fluid-structure interaction problem, Numer. Math, vol.87, pp.317-354, 2000. ,
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
Efficient implementation of finite element methods on nonmatching and overlapping meshes in three dimensions, SIAM Journal on Scientific Computing, vol.35, pp.23-47, 2013. ,
Unconditionally stable discretizations of the immersed boundary equations, J. Comput. Phys, vol.222, pp.702-719, 2007. ,
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
A semi-implicit approach for fluid-structure interaction based on an algebraic fractional step method, Math. Models Methods Appl. Sci, vol.17, pp.957-983, 2007. ,
LLM and X-FEM based interface modeling of fluid-thin structure interactions on a non-interface-fitted mesh, Comput. Mech, vol.48, pp.319-332, 2011. ,
Added mass effects of compressible and incompressible flows in fluidstructure interaction, J. Appl. Mech, vol.76, pp.21206-21213, 2009. ,
