A Semi-Implicit Material Point Method for the Continuum Simulation of Granular Materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2016
We present a new continuum-based method for the realistic simulation of large-scale free-flowing granular materials. We derive a compact model for the rheology of the material, which accounts for the exact nonsmooth Drucker-Prager yield criterion combined with a varying volume fraction. Thanks to a semi-implicit time-stepping scheme and a careful spatial discretization of our rheology built upon the Material-Point Method, we are able to preserve at each time step the exact coupling between normal and tangential stresses, in a stable way. This contrasts with previous approaches which either regularize or linearize the yield criterion for implicit integration, leading to unrealistic behaviors or visible grid artifacts. Remarkably, our discrete problem turns out to be very similar to the discrete contact problem classically encountered in multibody dynamics, which allows us to leverage robust and efficient nons-mooth solvers from the literature. We validate our method by successfully capturing typical macroscopic features of some classical experiments, such as the discharge of a silo or the collapse of a granular column. Finally, we show that our method can be easily extended to accommodate more complex scenarios including two-way rigid body coupling as well as anisotropic materials.
mpmGranular.pdf (15.53 Mo) Télécharger le fichier
mpmGranular-annex.pdf (151.68 Ko) Télécharger le fichier
Format : Figure, Image
hal-01310189 , version 1 (09-05-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
Gilles Daviet, Florence Bertails-Descoubes. A Semi-Implicit Material Point Method for the Continuum Simulation of Granular Materials. ACM Transactions on Graphics, 2016, SIGGRAPH '16 Technical Papers, 35 (4), pp.Article No. 102:1-13. ⟨10.1145/2897824.2925877⟩. ⟨hal-01310189⟩
2232 Consultations
782 Téléchargements
