A formulation of the linear discrete coulomb friction problem via convex optimization, ZAMM -Journal of Applied Mathematics and Mechanics, vol.91, issue.2, pp.155-175, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00495734
SPH granular flow with friction and cohesion, Proceedings of the 2011 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.25-32, 2011. ,
Simulation of high-resolution granular media, Proc. of Congreso Español de Informática Gráfica, 2009. ,
Granular media: between fluid and solid, 2011. ,
Particle-based simulation of granular materials, ACM SIGGRAPH/Eurographics Symposium on Computer Animation, Eurographics, 2005. ,
Numerical simulations of granular free-surface flows using smoothed particle hydrodynamics, Journal of Non- Newtonian Fluid Mechanics, vol.166, pp.12-13, 2011. ,
Nonsmooth simulation of dense granular flows with pressure-dependent yield stress, Journal of Non-Newtonian Fluid Mechanics, vol.234, pp.15-35, 2016. ,
A hybrid iterative solver for robustly capturing Coulomb friction in hair dynamics, ACM Transactions on Graphics, vol.30, issue.6, pp.1-12, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00647497
Power particles: An incompressible fluid solver based on power diagrams, ACM Transactions on Graphics, vol.34, issue.4, pp.1-11, 2015. ,
Continuum modelling and simulation of granular flows through their many phases, Journal of Fluid Mechanics, vol.779, pp.483-513, 2015. ,
Orientation behavior of fibers in concentrated suspensions, Journal of Reinforced Plastics and Composites, vol.3, pp.98-119, 1984. ,
A Lagrangian framework for simulating granular material with high detail, Computers & Graphics, vol.37, issue.7, pp.800-808, 2013. ,
Viscoplastic modeling of granular column collapse with pressure-dependent rheology, Journal of Non-Newtonian Fluid Mechanics, vol.219, pp.1-18, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01080456
The affine particle-in-cell method, ACM Transactions on Graphics, vol.34, issue.4, pp.1-10, 2015. ,
A constitutive law for dense granular flows, Nature, vol.441, pp.7094-727, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01432178
The granular column collapse as a continuum: validity of a twodimensional navier?stokes model with a µ(i)-rheology, Journal of Fluid Mechanics, vol.686, pp.378-408, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01444545
Mixing fluids and granular materials, In Computer Graphics Forum, vol.28, pp.213-218, 2009. ,
Simulating granular column collapse using the material point method, Acta Geotechnica, vol.10, pp.1-101, 2014. ,
Using Nesterov's method to accelerate multibody dynamics with friction and contact, ACM Transactions on Graphics, vol.34, issue.3, pp.1-14, 2015. ,
Free-flowing granular materials with two-way solid coupling, ACM Transactions on Graphics, vol.29, issue.6, pp.1-10, 2010. ,
Houdini 15.0 Grains, 2015. ,
The granular silo as a continuum plastic flow: The hour-glass vs the clepsydra, Physics of Fluids, vol.24, 2012. ,
A material point method for snow simulation, ACM Transactions on Graphics, vol.32, issue.4, pp.1-10, 2013. ,
Material point method in three-dimensional problems of granular flow, 6th European Conference on Computational Fluid Dynamics, 2015. ,
A particle-in-cell solution to the silo discharging problem, International Journal for Numerical Methods in Engineering, vol.45, pp.9-1203, 1999. ,
Animating sand as a fluid, ACM Transactions on Graphics, vol.24, issue.3, pp.965-972, 2005. ,
