Hybrid Monitoring of Attacker Knowledge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Enforcement of noninterference requires proving that an attacker's knowledge about the initial state remains the same after observing a program's public output. We propose a hybrid monitoring mechanism which dynamically evaluates the knowledge that is contained in program variables. To get a precise estimate of the knowledge, the monitor statically analyses non-executed branches. We show that our knowledge-based monitor can be combined with existing dynamic monitors for non-interference. A distinguishing feature of such a combination is that the combined monitor is provably more permissive than each mechanism taken separately. We demonstrate this by proposing a knowledge-enhanced version of a no-sensitive-upgrade (NSU) monitor. The monitor and its static analysis have been formalized and proved correct within the Coq proof assistant.
hybrid_monitoring_of_attacker_knowledge.pdf (1.4 Mo) Télécharger le fichier
hal-01310572 , version 1 (02-05-2016)
  • HAL Id : hal-01310572 , version 1
Frédéric Besson, Nataliia Bielova, Thomas Jensen. Hybrid Monitoring of Attacker Knowledge. 29th IEEE Computer Security Foundations Symposium, 2016, Lisboa, Portugal. ⟨hal-01310572⟩
378 Consultations
203 Téléchargements
