Linear interval observers under delayed measurements and delay-dependent positivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2016
New interval observers are designed for linear systems with time-varying delays in the case of delayed measurements. Interval observers employ positivity and stability analysis of the estimation error system, which in the case of delayed measurements should be delay-dependent. New delay-dependent conditions of positivity for linear systems with time-varying delays are introduced. Efficiency of the obtained solution is demonstrated on examples.
Interval_delay_osc_J.pdf (572.09 Ko) Télécharger le fichier
hal-01312981 , version 1 (09-05-2016)
Denis Efimov, Emilia Fridman, Andrey Polyakov, Wilfrid Perruquetti, Jean-Pierre Richard. Linear interval observers under delayed measurements and delay-dependent positivity. Automatica, 2016, 72, pp.123-130. ⟨10.1016/j.automatica.2016.05.022⟩. ⟨hal-01312981⟩
231 Consultations
397 Téléchargements
