The temporal logic of programs, 18th Annual Symposium on Foundations of Computer Science (sfcs 1977), pp.46-57, 1977. ,
DOI : 10.1109/SFCS.1977.32
Aspect-Oriented Instrumentation with GCC, Barringer et al. [36], pp.405-420 ,
DOI : 10.1007/978-3-642-16612-9_31
Runtime verification with the RV System, pp.136-152 ,
Runtime verification for the web-a tutorial introduction to interface contracts in web applications, pp.106-121 ,
Component-based development and verification of safety critical software for a brake-by-wire system with synchronous software components, Proceedings International Symposium on Software Engineering for Parallel and Distributed Systems PDSE-99, p.134, 1999. ,
DOI : 10.1109/PDSE.1999.779745
FlexRay schedule optimization of the static segment, Proceedings of the 7th IEEE/ACM international conference on Hardware/software codesign and system synthesis, CODES+ISSS '09, pp.363-372, 2009. ,
DOI : 10.1145/1629435.1629485
Timing analysis of the FlexRay communication protocol. Real-Time Syst, pp.205-235, 2008. ,
Software model checking takes off, Commun. ACM, vol.53, pp.58-64, 2010. ,
Automating with PROFINET: Industrial Communication Based on Industrial Ethernet, 2008. ,
Real-Time Ethernet - Industry Prospective, Proceedings of the IEEE, pp.1118-1129, 2005. ,
DOI : 10.1109/JPROC.2005.849720
Analysis of Deterministic Ethernet scheduling for the Industrial Internet of Things, 2014 IEEE 19th International Workshop on Computer Aided Modeling and Design of Communication Links and Networks (CAMAD), pp.320-324, 2014. ,
DOI : 10.1109/CAMAD.2014.7033258
Monitoring programs using rewriting, Proceedings 16th Annual International Conference on Automated Software Engineering (ASE 2001), pp.135-143, 2001. ,
DOI : 10.1109/ASE.2001.989799
Rewriting-Based Techniques for Runtime Verification, Automated Software Engineering, vol.32, issue.3, pp.151-197, 2005. ,
DOI : 10.1007/s10515-005-6205-y
Rule Systems for Run-time Monitoring: from EAGLE to RULER, Journal of Logic and Computation, vol.20, issue.3, pp.675-706, 2010. ,
DOI : 10.1093/logcom/exn076
Decentralised LTL Monitoring, Proceedings of the 18th International Symposium on Formal Methods (FM), pp.85-100, 2012. ,
DOI : 10.1007/978-3-642-32759-9_10
URL : https://hal.archives-ouvertes.fr/hal-00857286
Modeling Embedded Systems and SoC's: Concurrency and Time in Models of Computation, 2003. ,
Comparing LTL semantics for runtime verification . Logic and Computation, pp.651-674, 2010. ,
Runtime Verification for LTL and TLTL, ACM Transactions on Software Engineering and Methodology, vol.20, issue.4, p.14, 2011. ,
DOI : 10.1145/2000799.2000800
Planning for temporally extended goals, Annals of Mathematics and Artificial Intelligence, vol.22, issue.1/2, pp.5-27, 1998. ,
DOI : 10.1023/A:1018985923441
Model Checking of Safety Properties, Formal Methods in System Design, vol.19, issue.3, pp.291-314, 2001. ,
DOI : 10.1007/3-540-48683-6_17
Generating Optimal Linear Temporal Logic Monitors by Coinduction, Advances in Computing Science ? ASIAN 2003. Progamming Languages and Distributed Computation Programming Languages and Distributed Computation, pp.260-275, 2003. ,
DOI : 10.1007/978-3-540-40965-6_17
The complexity of propositional linear temporal logics, Journal of the ACM, vol.32, issue.3, pp.733-749, 1985. ,
The glory of the past, Conf. on Logic of Programs, pp.196-218, 1985. ,
DOI : 10.1007/3-540-15648-8_16
Temporal logic with past is exponentially more succinct, concurrency column, Bulletin of the EATCS, vol.79, pp.122-128, 2003. ,
Patterns in property specifications for finite-state verification, Intl. Conf. on Software Engineering (ICSE), pp.411-420, 1999. ,
New results on decentralized diagnosis of discrete event systems, Proc. 42nd Ann. Allerton Conf. on Communication, Control, and Computing, 2004. ,
Diagnosis of discrete event systems using decentralized architectures. Discrete Event Dynamic Systems, pp.233-263, 2007. ,
The Complexity of Codiagnosability for Discrete Event and Timed Systems, ATVA, pp.82-96, 2010. ,
DOI : 10.1007/978-3-642-15643-4_8
URL : https://hal.archives-ouvertes.fr/inria-00493640
Decentralized Observation Problems, Proceedings of the 44th IEEE Conference on Decision and Control, pp.6-11, 2005. ,
DOI : 10.1109/CDC.2005.1582122
Decentralized runtime analysis of multithreaded applications, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, 2006. ,
DOI : 10.1109/IPDPS.2006.1639591
Monitoring distributed controllers, Formal Methods (FM), pp.557-572, 2006. ,
Efficient and Generalized Decentralized Monitoring of Regular Languages, Lecture Notes in Computer Science, vol.8461, pp.66-83, 2014. ,
DOI : 10.1007/978-3-662-43613-4_5
