Fast brain decoding with random sampling and random projections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Machine learning from brain images is a central tool for image-based diagnosis and diseases characterization. Predicting behavior from functional imaging, brain decoding, analyzes brain activity in terms of the behavior that it implies. While these multivariate techniques are becoming standard brain mapping tools, like mass-univariate analysis, they entail much larger computational costs. In an time of growing data sizes, with larger cohorts and higher-resolutions imaging, this cost is increasingly a burden. Here we consider the use of random sampling and projections as fast data approximation techniques for brain images. We evaluate their prediction accuracy and computation time on various datasets and discrimination tasks. We show that the weight maps obtained after random sampling are highly consistent with those obtained with the whole feature space, while having a fair prediction performance. Altogether, we present the practical advantage of random sampling methods in neuroimaging, showing a simple way to embed back the reduced coefficients, with only a small loss of information.
paper.pdf (440.27 Ko) Télécharger le fichier
hal-01313814 , version 1 (10-05-2016)
  • HAL Id : hal-01313814 , version 1
Andrés Hoyos-Idrobo, Gaël Varoquaux, Bertrand Thirion. Fast brain decoding with random sampling and random projections. PRNI 2016: the 6th International Workshop on Pattern Recognition in Neuroimaging, Jun 2016, Trento, Italy. ⟨hal-01313814⟩
278 Consultations
478 Téléchargements
