TouchTokens: Guiding Touch Patterns with Passive Tokens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
TouchTokens make it possible to easily build interfaces that combine tangible and gestural input using passive tokens and a regular multi-touch surface. The tokens constrain users' grasp, and thus, the relative spatial configuration of fingers on the surface, theoretically making it possible to design algorithms that can recognize the resulting touch patterns. We performed a formative user study to collect and analyze touch patterns with tokens of varying shape and size. The analysis of this pattern collection showed that individual users have a consistent grasp for each token, but that this grasp is user-dependent and that different grasp strategies can lead to confounding patterns. We thus designed a second set of tokens featuring notches that constrain users' grasp. Our recognition algorithm can classify the resulting patterns with a high level of accuracy (>95%) without any training, enabling application designers to associate rich touch input vocabularies with command triggers and parameter controls.
touchtokens-hal.pdf (4.03 Mo) Télécharger le fichier
touchtokens-CHI2016.mp4 (58.79 Mo) Télécharger le fichier
hal-01315130 , version 1 (12-05-2016)
Rafael Morales Gonzalez, Caroline Appert, Gilles Bailly, Emmanuel Pietriga. TouchTokens: Guiding Touch Patterns with Passive Tokens. Proceedings of the 2016 CHI Conference on Human Factors in Computing Systems, May 2016, San Jose, CA, United States. pp.4189-4202, ⟨10.1145/2858036.2858041⟩. ⟨hal-01315130⟩
882 Consultations
1332 Téléchargements
