The complexity of the majority rule on planar graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Mathematics Année : 2015
We study the complexity of the majority rule on planar automata networks. We reduce a special case of the Monotone Circuit Value Problem to the prediction problem of determining if a vertex of a planar graph will change its state when the network is updated with the majority rule.
hal-01315322 , version 1 (13-05-2016)
Eric Goles Chacc, Pedro Montealegre. The complexity of the majority rule on planar graphs. Advances in Applied Mathematics, 2015, 64, pp.111-123. ⟨10.1016/j.aam.2014.11.005⟩. ⟨hal-01315322⟩
27 Consultations
0 Téléchargements
