The COUPLEX Test Cases: Nuclear Waste Disposal Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geosciences Année : 2004
The models appearing in the COUPLEX benchmark are a set of simplified albeit realistic test cases aimed at simulating the transport of radionuclides around a nuclear waste repository. Three different models were used: The first test case is related to simulations based on a simplified 2D far-field model close to those used for safety assessments in nuclear waste management. It leads to a classical convec-tion diffusion type problem, but with highly variable parameters in space, highly concentrated sources in space and time, very different time scales and accurate results expected even after millions of years. The second test case is a simplification of a typical 3D near-field computation, taking into account the glass dissolution of vitrified waste, and the congruent release of several radionu-clides (including daughter products), with their migration through the geological barrier. The aim of the third test case is to use the results of the near-field computation (COUPLEX 2) to drive the behavior of the nuclide source term in the Far Field computation (COUPLEX 1). The modeling of this last case was purposely left rather open, unlike the previous two, leaving the choice to participants of the way the coupling should be made.
couplex.pdf (120.58 Ko) Télécharger le fichier
hal-01315461 , version 1 (13-05-2016)
Alain Bourgeat, Michel Kern, Stephan Schumacher, Jean Talandier. The COUPLEX Test Cases: Nuclear Waste Disposal Simulation. Computational Geosciences, 2004, ⟨10.1023/B:COMG.0000035073.03009.5d⟩. ⟨hal-01315461⟩
419 Consultations
211 Téléchargements
