Task-based Conjugate Gradient: from multi-GPU towards heterogeneous architectures
Whereas most parallel High Performance Computing (HPC) numerical libaries have
been written as highly tuned and mostly monolithic codes, the increased complexity of modern
architectures led the computational science and engineering community to consider more mod-
ular programming paradigms such as task-based paradigms to design new generation of parallel
simulation code; this enables to delegate part of the work to a third party software such as a
runtime system. That latter approach has been shown to be very productive and efficient with
compute-intensive algorithms, such as dense linear algebra and sparse direct solvers. In this study,
we consider a much more irregular, and synchronizing algorithm, namely the Conjugate Gradient
(CG) algorithm. We propose a task-based formulation of the algorithm together with a very fine
instrumentation of the runtime system. We show that almost optimum speed up may be reached on
a multi-GPU platform (relatively to the mono-GPU case) and, as a very preliminary but promising
result, that the approach can be effectively used to handle heterogenous architectures composed of a
multicore chip and multiple GPUs. We expect that these results will pave the way for investigating
the design of new advanced, irregular numerical algorithms on top of runtime systems.
