Photomechanics Topics in Applied Physic, pp.978-981, 2000. ,
Full-field measurements and identification in solid mechanics, 2012. ,
DOI : 10.1002/9781118578469
Moiré interferentieverschijnselen bij rasterdruck, 1945. ,
Utilisation de réseaux pour l'´ etude experimentale des phénomènes phénomènesélastiques et plastiques, Comptes Rendus de l'Académie des Sciences, pp.1769-1771, 1954. ,
Exposé général d'une méthode experimentale de détermination directe des déformations dans un solide, 9` eme congrès international de mécanique appliquée, pp.490-497, 1957. ,
Moiré fringes in strain analysis, 1969. ,
Speckle Interferometry: A Review of the Principal Methods in Use for Experimental Mechanics Applications, Strain, vol.44, issue.1, pp.67-69, 2008. ,
DOI : 10.1111/j.1475-1305.2008.00372.x
Handbook of holographic interferometry: optical and digital methods, pp.978-981, 2004. ,
DOI : 10.1002/3527604154
Moir?? interferometry: Advances and applications, Experimental Mechanics, vol.28, issue.15, pp.276-280, 1991. ,
DOI : 10.1007/BF02326072
Image Correlation for Shape, Motion and Deformation Measurements Basic Concepts,Theory and Applications, 2009. ,
Two-dimensional digital image correlation for in-plane displacement and strain measurement: a review, Measurement Science and Technology, vol.20, issue.6, p.62001, 2009. ,
DOI : 10.1088/0957-0233/20/6/062001
Optimized Patterns for Digital Image Correlation, Proceedings of the 2012 Annual Conference on Experimental and Applied Mechanics Imaging Methods for Novel Materials and Challenging Applications, 2013. ,
DOI : 10.1007/978-1-4614-4235-6_34
The grid method, Experimental Mechanics, vol.VIII, issue.2, pp.27-33, 1969. ,
DOI : 10.1007/BF02325141
An application of pattern mapping to plane motion, Experimental Mechanics, vol.30, issue.4, pp.404-410, 1990. ,
DOI : 10.1007/BF02321512
Grid Circle Analyzer - Computer Aided Measurement of Deformation, SAE Technical Paper Series, 1979. ,
DOI : 10.4271/790741
Determination of large strains in metalforming, The Journal of Strain Analysis for Engineering Design, vol.17, issue.2, pp.95-101, 1982. ,
DOI : 10.1243/03093247V172095
The evaluation of large strains from industrial sheet metal stampings with a square grid, Journal of Applied Metalworking, vol.6, issue.1, pp.143-156, 1986. ,
DOI : 10.1007/BF02834378
The automated measurement of strains from three-dimensional deformed surfaces, JOM, vol.17, issue.3, pp.8-13, 1990. ,
DOI : 10.1007/BF03220863
Recent developments in a vision-based surface strain measurement system, JOM, vol.13, issue.4, pp.46-49, 1990. ,
DOI : 10.1007/BF03221231
Chapter 6 Grid strain analysis and its application in composite sheet forming, Composite Materials Series, pp.217-245, 1997. ,
DOI : 10.1016/S0927-0108(97)80008-2
Grid Method for Microscale Discontinuous Deformation Measurement, Experimental Mechanics, vol.46, issue.2, pp.565-574, 2011. ,
DOI : 10.1007/s11340-010-9459-7
Grid-based matching for full-field large-area deformation measurement, Optics and Lasers in Engineering, vol.66, pp.307-319, 2015. ,
DOI : 10.1016/j.optlaseng.2014.10.003
Determination of the Energy Storage Rate Distribution in the Area of Strain Localization Using Infrared and Visible Imaging, Experimental Mechanics, vol.550, issue.4, pp.53-760, 2015. ,
DOI : 10.1007/s11340-013-9819-1
Applications of digital-image-correlation techniques to experimental mechanics, Experimental Mechanics, vol.1, issue.3, pp.232-244, 1983. ,
DOI : 10.1007/BF02325092
Experimental characterization of the local strain field in a heterogeneous elastoplastic material, Acta Metallurgica et Materialia, vol.42, issue.11, pp.423865-3880, 1994. ,
DOI : 10.1016/0956-7151(94)90452-9
PRODUCING AND TRANSFERRING LOW-SPATIAL-FREQUENCY GRIDS FOR MEASURING DISPLACEMENT FIELDS WITH MOIRE AND GRID METHODS, Experimental Techniques, vol.21, issue.5, pp.23-26, 2004. ,
DOI : 10.1007/BF02327139
Threedimensional displacement and shape measurement with a diffraction-assisted grid method, Strain, vol.49, issue.5, pp.399-408, 2013. ,
Strain Measurement Using Grids, Optical Engineering, vol.21, issue.4, pp.633-639, 1982. ,
DOI : 10.1117/12.7972958
The photonical, pure grid method, Optics and Lasers in Engineering, vol.18, issue.3, pp.173-194, 1993. ,
DOI : 10.1016/0143-8166(93)90026-H
Quantitative measurement of displacement and strain fields from HREM micrographs, Ultramicroscopy, vol.74, issue.3, pp.131-146, 1998. ,
DOI : 10.1016/S0304-3991(98)00035-7
Imaging conditions for reliable measurement of displacement and strain in high-resolution electron microscopy, Ultramicroscopy, vol.87, issue.4, pp.199-212, 2001. ,
DOI : 10.1016/S0304-3991(00)00099-1
Calibration of projector lens distortions, Journal of Electron Microscopy, vol.54, issue.3, pp.181-190, 2005. ,
DOI : 10.1093/jmicro/dfi042
In-plane deformation measurement using the atomic force microscope moir?? method, Nanotechnology, vol.11, issue.1, pp.24-29, 2000. ,
DOI : 10.1088/0957-4484/11/1/305
AFM scanning moiré method for nanodeformation measurement ,
A study on the digital nanomoiré method and its phase shifting technique, Measuring Science and Technology, vol.15, pp.716-721, 2004. ,
Study of moir?? grating fabrication on metal samples using nanoimprint lithography, Optics Express, vol.20, issue.3, pp.2942-2955, 2012. ,
DOI : 10.1364/OE.20.002942
Electron beam moir??, Experimental Mechanics, vol.7, issue.4, pp.270-277 ,
DOI : 10.1007/BF02322141
Theory of electron beam moire, Journal of Research of the National Institute of Standards and Technology, vol.101, issue.1, pp.47-61, 1996. ,
DOI : 10.6028/jres.101.007
Advances in scanning electron microscope moir??, Experimental Mechanics, vol.9, issue.1, pp.165-173, 2001. ,
DOI : 10.1007/BF02323193
Fabrication of high aspect ratio subwavelength gratings based on X-ray lithography and electron beam lithography, Optics & Laser Technology, vol.44, issue.6, pp.1649-53, 2012. ,
DOI : 10.1016/j.optlastec.2011.11.051
Focused ion beam Moir?? method, Optics and Lasers in Engineering, vol.40, issue.3, pp.163-177, 2003. ,
DOI : 10.1016/S0143-8166(02)00099-4
Focused ion beam (FIB) nano-machining and FIB Moire technique for strain analysis in MEMS/NEMS structures and devices, The Sixteenth Annual International Conference on Micro Electro Mechanical Systems, 2003. MEMS-03 Kyoto. IEEE, pp.674-677, 2003. ,
DOI : 10.1109/MEMSYS.2003.1189839
Fabrication of highfrequency moiré gratings for microscopic deformation measurement using focused ion beam milling, Optics and Lasers in Engineering, vol.20, issue.5, p.55037, 2010. ,
FIB moiré gratings and their application in the measurement of optical fibers' mechanical properties, Chinese Physics Letters, vol.29, p.34210, 2012. ,
Experimental investigation and micromechanical modeling of the hot deformation of duplex stainless steels, Proceedings of the International Conference on Mathematical Modelling in Metal Processing and Manufacturing-COM 2000, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00117792
Comparison of experimental results and finite element simulation of strain localization scheme under cyclic loading, Computational Materials Science, vol.46, issue.3, pp.755-760, 2009. ,
DOI : 10.1016/j.commatsci.2009.04.037
Characterization of the High Temperature Strain Partitioning in Duplex Steels, Experimental Mechanics, vol.55, issue.174, pp.205-215, 2013. ,
DOI : 10.1007/s11340-012-9628-y
URL : https://hal.archives-ouvertes.fr/hal-00839659
High-frequency, High-reflectance Transferable Moir?? Gratings, Experimental Techniques, vol.8, issue.5, pp.29-31, 1984. ,
DOI : 10.1111/j.1747-1567.1984.tb01905.x
Dynamic stress analysis by high-resolution reflection moire photography, Optical Engineering, vol.33, issue.3, pp.924-931 ,
DOI : 10.1117/12.157660
Grid method for strain measurement in electronic packaging using optical, electronic, and atomic force microscopy, Proc. SPIE 3897, Advanced Photonic Sensors and Applications, 1999. ,
Microscopic grid methods???resolution and sensitivity, Optics and Lasers in Engineering, vol.36, issue.5, pp.437-450, 2001. ,
DOI : 10.1016/S0143-8166(01)00071-9
High resolution AFM scanning moiré method and its application to the microdeformation in the BGA electronic package, Microelectonics Reliability, issue.8, pp.421219-1227, 2002. ,
Strain measurements in the nanometer range in a particulate composite using computer-aided moir??, Experimental Mechanics, vol.49, issue.10, pp.341-347, 2003. ,
DOI : 10.1007/BF02410533
Measurement of deformation fields in polycrystalline OFHC copper, International Journal of Plasticity, vol.19, issue.9, pp.1355-1376, 2003. ,
DOI : 10.1016/S0749-6419(02)00040-2
On the realization of microscopic grids for local strain measurement by direct interferometric photolithography, Optics and Lasers in Engineering, vol.45, issue.12, pp.1131-1147, 2007. ,
DOI : 10.1016/j.optlaseng.2007.06.009
Scanning moir?? at high magnification using optical methods, Experimental Mechanics, vol.7, issue.4, pp.110-116, 1993. ,
DOI : 10.1007/BF02322486
High Sensitivity Moire-Experimental Analysis for Mechanics and Materials, 1994. ,
Caract??risation de la r??partition de la d??formation dans les mat??riaux h??t??rog??nesCharacterisation of the strain distribution in heterogeneous materials, M??canique & Industries, vol.4, issue.6, pp.607-617, 2003. ,
DOI : 10.1016/j.mecind.2003.09.002
Grid Method, Moir?? and Deflectometry, Full-field Measurements and Identification in Solid Mechanics, pp.61-89, 2012. ,
DOI : 10.1002/9781118578469.ch3
The rapid deposition of moir?? grids, Experimental Mechanics, vol.43, issue.5, pp.375-377, 1971. ,
DOI : 10.1007/BF02320540
Automated fine grid technique for measurement of large-strain deformation maps, Optics and Lasers in Engineering, vol.23, issue.5, pp.305-318, 1995. ,
DOI : 10.1016/0143-8166(95)00036-N
In Plane Displacement Formulation for Finite Cracked Plates Under Mode I Using Grid Method and Finite Element Analysis, Experimental Mechanics, vol.8, issue.4, pp.401-412, 2010. ,
DOI : 10.1007/s11340-009-9225-x
High strain gradient measurements using modified automated grid technique, Optics and Lasers in Engineering, vol.52, pp.140-144, 2014. ,
DOI : 10.1016/j.optlaseng.2013.06.019
Development and validation of a time-domain fringe pattern analysis technique for the measurement of object shape and deformation, 2015. ,
Grid method: Application to the characterization of cracks, Experimental Mechanics, vol.35, issue.3, pp.37-43, 2004. ,
DOI : 10.1007/BF02427974
A refined study of the crack propagation in cement-based composite beams under bending. Cement and Concrete Composites, pp.399-411, 2005. ,
Applying a Full-Field Measurement Technique to Characterize the Mechanical Response of a Sunflower-Based Biocomposite, Experimental Mechanics, vol.28, issue.4, pp.917-934, 2015. ,
DOI : 10.1007/s11340-015-9988-1
Strain analysis by mismatch moire method and grid method using Fourier transform, Computational Mechanics, vol.22, issue.8, pp.1-10, 1990. ,
DOI : 10.1007/BF00373795
Measurement of dynamic large-strain deformation maps using an automated fine grid technique, Optics and Lasers in Engineering, vol.31, issue.2, pp.31113-122, 1999. ,
DOI : 10.1016/S0143-8166(99)00003-2
Sampling Moir?? Method for Accurate Small Deformation Distribution Measurement, Experimental Mechanics, vol.27, issue.24, pp.501-508, 2010. ,
DOI : 10.1007/s11340-009-9239-4
Accuracy of the Sampling Moir?? Method and its Application to Deflection Measurements of Large-Scale Structures, Experimental Mechanics, vol.194, issue.10, pp.331-3340, 2012. ,
DOI : 10.1007/s11340-011-9491-2
Noncontact Deflection Distribution Measurement for Large-Scale Structures by Advanced Image Processing Technique, MATERIALS TRANSACTIONS, vol.53, issue.2, pp.323-329, 2012. ,
DOI : 10.2320/matertrans.I-M2011852
GPA Combined with the Hole-Drilling Method Applied for Curved Surface Strain Measurement, Strain, vol.86, issue.1, pp.46-53, 2012. ,
DOI : 10.1111/str.12011
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.20095102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
Moiré and grid methods: a signal-processing approach, Proceedings SPIE, Interferometry '94: Photomechanics, pp.118-127, 1994. ,
Fourier-transform method of fringe-pattern analysis for computer-based topography and interferometry, Journal of the Optical Society of America, vol.72, issue.1, pp.156-160, 1982. ,
DOI : 10.1364/JOSA.72.000156
Fourier transform profilometry for the automatic measurement of 3-D object shapes, Applied Optics, vol.22, issue.24, pp.3977-3982, 1983. ,
DOI : 10.1364/AO.22.003977
Spatial-carrier fringe-pattern analysis and its applications to precision interferometry and profilometry: An overview, Industrial Metrology, vol.1, issue.2, pp.79-99, 1990. ,
DOI : 10.1016/0921-5956(90)80019-R
An introduction to metric spaces and fixed point theory, 2001. ,
Noise-immune phase unwrapping algorithm, Applied Optics, vol.28, issue.16, pp.3268-3270, 1989. ,
DOI : 10.1364/AO.28.003268
Temporal phase-unwrapping algorithm for automated interferogram analysis, Applied Optics, vol.32, issue.17, pp.3047-3052, 1993. ,
DOI : 10.1364/AO.32.003047
Robust, simple, and fast algorithm for phase unwrapping, Applied Optics, vol.35, issue.29, pp.5847-5852, 1996. ,
DOI : 10.1364/AO.35.005847
Automated fringe pattern analysis in experimental mechanics: a review, The Journal of Strain Analysis for Engineering Design, vol.23, issue.2, pp.105-125, 1998. ,
DOI : 10.1243/0309324981512850
Two-dimensional phase unwrapping: theory, algorithm and software, 1998. ,
Measuring instantaneous frequencies of fringe image and its application in phase unwrapping, Acta Electron Sinica, vol.27, pp.15-23, 1999. ,
Fast two-dimensional phase-unwrapping algorithm based on sorting by reliability following a noncontinuous path, Applied Optics, vol.41, issue.35, pp.417437-7444, 2002. ,
DOI : 10.1364/AO.41.007437
Robust, fast, and effective two-dimensional automatic phase unwrapping algorithm based on image decomposition, Applied Optics, vol.41, issue.35, pp.417445-7455, 2002. ,
DOI : 10.1364/AO.41.007445
Agglomerative clustering-based approach for two-dimensional phase unwrapping, Applied Optics, vol.44, issue.7, pp.1129-1140, 2005. ,
DOI : 10.1364/AO.44.001129
Comparison of eight unwrapping algorithms applied to Fourier-transform profilometry, Optics and Lasers in Engineering, vol.46, issue.2, pp.106-116, 2008. ,
DOI : 10.1016/j.optlaseng.2007.09.002
A Procedure for Accurate One-Dimensional Strain Measurement Using the Grid Method, Experimental Mechanics, vol.29, issue.7???8, pp.841-854, 2009. ,
DOI : 10.1007/s11340-008-9203-8
Effect of interpolation on noise propagation from images to DIC displacement maps, International Journal for Numerical Methods in Engineering, vol.50, issue.1, 2016. ,
DOI : 10.1002/nme.5212
URL : https://hal.archives-ouvertes.fr/hal-01255944
On the Propagation of Camera Sensor Noise to Displacement Maps Obtained by DIC - an Experimental Study, Experimental Mechanics, vol.45, issue.2, 2016. ,
DOI : doi:10.1002/nme.5212
URL : https://hal.archives-ouvertes.fr/hal-01269655
Estimation of the strain field from full-field displacement noisy data. Comparing finite elements global least squares and polynomial diffuse approximation, Revue europ??enne de m??canique num??rique, vol.17, issue.5-6-7, pp.5-7857, 2008. ,
DOI : 10.3166/remn.17.857-868
URL : https://hal.archives-ouvertes.fr/emse-00497681
Comparison of two approaches for differentiating full-field data in solid mechanics, Measurement Science and Technology, vol.21, issue.1, p.15703, 2010. ,
DOI : 10.1088/0957-0233/21/1/015703
URL : https://hal.archives-ouvertes.fr/emse-00509118
Fourier transform profilometry:, Optics and Lasers in Engineering, vol.35, issue.5, pp.263-284, 2001. ,
DOI : 10.1016/S0143-8166(01)00023-9
Fourier fringe analysis and its application to metrology of extreme physical phenomena: a review [Invited], Applied Optics, vol.52, issue.1, pp.20-29, 2013. ,
DOI : 10.1364/AO.52.000020
Windowed Fourier transform for fringe pattern analysis, Applied Optics, vol.43, issue.13, pp.2695-2702, 2004. ,
DOI : 10.1364/AO.43.002695
Two-dimensional windowed Fourier transform for fringe pattern analysis: Principles, applications and implementations, Optics and Lasers in Engineering, vol.45, issue.2, pp.304-317, 2007. ,
DOI : 10.1016/j.optlaseng.2005.10.012
Applications of windowed Fourier fringe analysis in optical measurement: A review, Optics and Lasers in Engineering, vol.66, issue.2, pp.67-73, 2015. ,
DOI : 10.1016/j.optlaseng.2014.08.012
Moir?? interferogram phase extraction: a ridge detection algorithm for continuous wavelet transforms, Applied Optics, vol.43, issue.4, pp.850-857, 2004. ,
DOI : 10.1364/AO.43.000850
Spatial carrier-fringe pattern analysis by means of wavelet transform: wavelet transform profilometry, Applied Optics, vol.43, issue.26, pp.4993-4998, 2004. ,
DOI : 10.1364/AO.43.004993
Phase retrieval of optical fringe patterns from the ridge of a wavelet transform, Optics Letters, vol.30, issue.19, pp.2560-2562, 2005. ,
DOI : 10.1364/OL.30.002560
High-sensitivity measurement of strain by moiré interferometry. Transactions of the Japan Society for Mechanical Engineers Series A, pp.122-127, 1987. ,
Two-dimensional moir?? method and grid method using Fourier transform, Experimental Mechanics, vol.9, issue.11, pp.399-404, 1989. ,
DOI : 10.1007/BF02323857
Non-contact non-disturbing local strain measurement method. I-principle, European Journal of Mechanics A/Solids, vol.11, issue.3, pp.349-366, 1992. ,
Non-contact and non-disturbing local strain measurement methods. 2-applications, European Journal of Mechanics, A/Solids, vol.11, issue.3, pp.367-379, 1992. ,
Numerical spectral analysis of a grid: Application to strain measurements, Optics and Lasers in Engineering, vol.18, issue.3, pp.159-172, 1993. ,
DOI : 10.1016/0143-8166(93)90025-G
CURRENT TRENDS IN OBTAINING DEFORMATION DATA FROM GRIDS, Experimental Techniques, vol.307, issue.10, pp.22-26, 1993. ,
The geometric phase analysis method based on the local high resolution discrete Fourier transform for deformation measurement, Measurement Science and Technology, vol.25, issue.2, p.25402, 2014. ,
DOI : 10.1088/0957-0233/25/2/025402
Geometric phase analysis of high-resolution electron microscopy images of antiphase domains: example Cu3Au, Philosophical Magazine A, vol.74, pp.1119-1138, 1997. ,
Design of algorithms for phase measurements by the use of phase stepping, Applied Optics, vol.35, issue.1, pp.51-60, 1996. ,
DOI : 10.1364/AO.35.000051
Geometric phase analysis based on the windowed Fourier transform for the deformation field measurement, Optics & Laser Technology, vol.58, issue.6, pp.119-127, 2014. ,
DOI : 10.1016/j.optlastec.2013.11.010
Phase demodulation method from a single fringe pattern based on correlation with a polynomial form, Applied Optics, vol.44, issue.34, pp.7261-7269, 2005. ,
DOI : 10.1364/AO.44.007261
Theoretical error analysis of the sampling moir?? method and phase compensation methodology for single-shot phase analysis, Applied Optics, vol.51, issue.16, pp.3214-3223, 2012. ,
DOI : 10.1364/AO.51.003214
Demodulation of spatial carrier images: Performance analysis of several algorithms, Experimental Mechanics, issue.8, pp.531357-1370, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00834981
Comparison of Fourier transform, windowed Fourier transform, and wavelet transform methods for phase extraction from a single fringe pattern in fringe projection profilometry, Optics and Lasers in Engineering, vol.48, issue.2, pp.141-148, 2010. ,
DOI : 10.1016/j.optlaseng.2009.04.003
<title>Spatial-carrier phase-shifting technique of fringe pattern analysis</title>, Industrial Applications of Holographic and Speckle Measuring Techniques, pp.61-67, 1991. ,
DOI : 10.1117/12.47089
Phase stepping: a new self-calibrating algorithm, Applied Optics, vol.32, issue.19, pp.3598-3600, 1993. ,
DOI : 10.1364/AO.32.003598
Two-directional spatial-carrier phase-shifting method for analysis of complex interferograms In Interferometry 94: New techniques and analysis in optical measurements, pp.163-169, 1994. ,
Additive noise effect in digital phase detection, Applied Optics, vol.36, issue.1, pp.271-276, 1997. ,
DOI : 10.1364/AO.36.000271
Design of phase-detection algorithms insensitive to bias modulation, Applied Optics, vol.36, issue.4, pp.805-807, 1997. ,
DOI : 10.1364/AO.36.000805
Phase-shifting algorithms for nonlinear and spatially nonuniform phase shifts: comment, Journal of the Optical Society of America A, vol.15, issue.5, pp.1227-1233, 1998. ,
DOI : 10.1364/JOSAA.15.001227
Extended averaging and data windowing techniques in phase-stepping measurements: an approach using the characteristic polynomial theory, Optical Engineering, vol.37, issue.8, pp.2314-2319, 1998. ,
DOI : 10.1117/1.601753
Phase-shifting sample self-calibration algorithm insensitive to the 2nd-harmonics in the fringe signal, Optical Engineering, vol.34, issue.9, pp.2821-2822, 1995. ,
Effect of quantization error on the computed phase of phase-shifting measurements, Applied Optics, vol.36, issue.10, pp.2070-2075, 1997. ,
DOI : 10.1364/AO.36.002070
Spatial carrier phase-shifting algorithm based on least-squares iteration, Applied Optics, vol.47, issue.29, pp.5446-5453, 2008. ,
DOI : 10.1364/AO.47.005446
Influence of the Analysis Window on the Metrological Performance of the Grid Method, Journal of Mathematical Imaging and Vision, vol.55, issue.2, 2016. ,
DOI : 10.1007/s10851-016-0650-z
URL : https://hal.archives-ouvertes.fr/hal-01298523
A Wavelet Tour of Signal Processing, 2008. ,
Calibration and evaluation of optical systems for full-field strain measurement, Optics and Lasers in Engineering, vol.45, issue.5, pp.45550-564, 2007. ,
DOI : 10.1016/j.optlaseng.2006.08.012
Progress in developing a standard for dynamic strain analysis, Experimental and Applied Mechanics of Conference Proceedings of the Society for Experimental Mechanics Series, pp.425-429, 2011. ,
DOI : 10.1007/978-1-4614-0222-0_52
he development of a reference material for calibration of full-field optical measurement systems for dynamic deformation measurements, Applied Mechanics and Materials, pp.33-38, 2011. ,
A reference material for establishing uncertainties in full-field displacement measurements, Measurement Science and Technology, vol.26, issue.7, p.75004, 2015. ,
DOI : 10.1088/0957-0233/26/7/075004
Uncertainty quantification in DIC with Kriging regression, Optics and Lasers in Engineering, vol.78, pp.182-195, 2016. ,
DOI : 10.1016/j.optlaseng.2015.09.006
Draft standard guide for optical deformation measurements in dynamic events, 2011. ,
Stress intensity factor measurements from digital image correlation: post-processing and integrated approaches, International Journal of Fracture, vol.40, issue.1, pp.141-157, 2006. ,
DOI : 10.1007/s10704-006-6631-2
URL : https://hal.archives-ouvertes.fr/hal-00013818
Statistical Analysis of the Effect of Intensity Pattern Noise on the Displacement Measurement Precision of Digital Image Correlation Using Self-correlated Images, Experimental Mechanics, vol.43, issue.6, pp.47701-707, 2007. ,
DOI : 10.1007/s11340-006-9005-9
Experimental investigation of localized phenomena using digital image correlation, Philosophical Magazine, vol.364, issue.28-29, pp.28-293339, 2008. ,
DOI : 10.1002/nme.849
Use of rigid-body motion for the investigation and estimation of the measurement errors related to digital image correlation technique, Optics and Lasers in Engineering, vol.46, issue.2, pp.185-96, 2008. ,
DOI : 10.1016/j.optlaseng.2007.05.008
Assessment of measuring errors in DIC using deformation fields generated by plastic FEA, Optics and Lasers in Engineering, vol.47, issue.7-8, pp.747-53, 2009. ,
DOI : 10.1016/j.optlaseng.2009.03.007
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.45160-78, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
A fully integrated noise robust strategy for the identification of constitutive laws from digital images, International Journal for Numerical Methods in Engineering, vol.199, issue.21-22, pp.631-660, 2010. ,
DOI : 10.1002/nme.2908
On Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.51, issue.4, pp.405-422, 2011. ,
DOI : 10.1007/s11340-010-9449-9
Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.46, issue.3, pp.423-441, 2011. ,
DOI : 10.1007/s11340-010-9450-3
Comparison of Local and Global Approaches to Digital Image Correlation, Experimental Mechanics, vol.39, issue.8, pp.1503-1519, 2012. ,
DOI : 10.1007/s11340-012-9603-7
URL : https://hal.archives-ouvertes.fr/hal-00750756
International vocabulary of metrology ? Basic and general concepts and associated terms (VIM), BIPM, 2008. ,
Impact of lens distortions on strain measurements obtained with 2D digital image correlation, Optics and Lasers in Engineering, vol.51, issue.5, pp.576-584, 2013. ,
DOI : 10.1016/j.optlaseng.2012.12.009
High-Accuracy 2D Digital Image Correlation Measurements with Bilateral Telecentric Lenses: Error Analysis and Experimental Verification, Experimental Mechanics, vol.44, issue.1, pp.1719-1733, 2013. ,
DOI : 10.1007/s11340-013-9774-x
Evaluation of Methodologies for Compensation of Out of Plane Motions in a 2D Digital Image Correlation Setup, Strain, vol.49, issue.5, pp.357-369, 2015. ,
DOI : 10.1111/str.12146
Basics of Metrology and Introduction to Techniques, Full-field Measurements and Identification in Solid Mechanics, pp.1-29, 2012. ,
DOI : 10.1002/9781118578469.ch1
Assessment of Digital Image Correlation Measurement Errors: Methodology and Results, Experimental Mechanics, vol.43, issue.4, pp.49353-370, 2009. ,
DOI : 10.1007/s11340-008-9204-7
URL : https://hal.archives-ouvertes.fr/hal-00881043
A Self Adaptive Global Digital Image Correlation Algorithm, Experimental Mechanics, vol.48, issue.6, pp.361-378, 2015. ,
DOI : 10.1007/s11340-014-9946-3
Ncorr: Open-Source 2D Digital Image Correlation Matlab Software, Experimental Mechanics, vol.29, issue.6, pp.1105-1122, 2015. ,
DOI : 10.1007/s11340-015-0009-1
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, pp.716-734, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.009
Linear and Nonlinear Models: Fixed Effects, Random Effects, and Mixed Models, 2006. ,
DOI : 10.1007/978-3-642-22241-2
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Uncertainty on fringe projection technique: A Monte-Carlo-based approach, Optics and Lasers in Engineering, vol.51, issue.7, pp.840-847, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.023
URL : https://hal.archives-ouvertes.fr/hal-01024470
Sur lesprobì emes aux dérivées partielles et leur signification physique, Princeton University Bulletin, vol.13, pp.49-52, 1902. ,
Deconvolution in astronomy: a review. Publications of the astronomical society of the pacific, pp.1051-1069, 2002. ,
Determining displacement and strain maps immune from aliasing effect with the grid method, Optics and Lasers in Engineering, vol.86, 2016. ,
DOI : 10.1016/j.optlaseng.2016.06.010
URL : https://hal.archives-ouvertes.fr/hal-01352868
Optimisation de la dérivation en fonction de la résolution et de la résolution spatiale sur les déformations, Proceedings of the 19th French National Conference on Mechanics, pp.1-6, 2009. ,
Improved Assessment of Significant Activation in Functional Magnetic Resonance Imaging (fMRI): Use of a Cluster-Size Threshold, Magnetic Resonance in Medicine, vol.17, issue.5, pp.636-647, 1995. ,
DOI : 10.1002/mrm.1910330508
Introduction to random field theory, Human brain function, Part II, 2003. ,
Developments in random field theory, Human brain function, Part II, 2003. ,
Implicit and explicit camera calibration: theory and experiments, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.5, pp.469-480, 1994. ,
´ Etalonnage transverse d'un objectif de caméra par la méthode de la grille, Proceedings of Photomécanique 2004, pp.257-264, 2004. ,
A flexible new technique for camera calibration, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.22, issue.11, 1998. ,
DOI : 10.1109/34.888718
A four-step camera calibration procedure with implicit image correction, Proceedings of IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.1106-1112, 1997. ,
DOI : 10.1109/CVPR.1997.609468
Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Patch-Based Nonlocal Functional for Denoising Fluorescence Microscopy Image Sequences, IEEE Transactions on Medical Imaging, vol.29, issue.2, pp.442-454, 2010. ,
DOI : 10.1109/TMI.2009.2033991
URL : https://hal.archives-ouvertes.fr/inria-00541082
CCD noise removal in digital images, IEEE Transactions on Image Processing, vol.15, issue.9, pp.2676-2685, 2006. ,
DOI : 10.1109/TIP.2006.877363
Practical Poissonian-Gaussian Noise Modeling and Fitting for Single-Image Raw-Data, IEEE Transactions on Image Processing, vol.17, issue.10, pp.1737-1754, 2008. ,
DOI : 10.1109/TIP.2008.2001399
THE TRANSFORMATION OF POISSON, BINOMIAL AND NEGATIVE-BINOMIAL DATA, Biometrika, vol.35, issue.3-4, pp.246-254, 1948. ,
DOI : 10.1093/biomet/35.3-4.246
Image restoration with noise suppression using a multiresolution support, Astronomy and astrophysics, vol.112, pp.179-189, 1995. ,
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
On noise reduction in strain maps obtained with the grid method by averaging images affected by vibrations, Optics and Lasers in Engineering, vol.66, pp.210-222, 2015. ,
DOI : 10.1016/j.optlaseng.2014.09.013
URL : https://hal.archives-ouvertes.fr/hal-01075764
Sampling and reconstruction of wave-number-limited functions in N-dimensional euclidean spaces, Information and Control, vol.5, issue.4, pp.279-323, 1962. ,
DOI : 10.1016/S0019-9958(62)90633-2
Removing quasi-periodic noise in strain maps by filtering in the Fourier domain. Experimental Techniques, 2015. ,
Automated removal of quasiperiodic noise using frequency domain statistics, Journal of Electronic Imaging, vol.24, issue.1, pp.13003-13004, 2015. ,
DOI : 10.1117/1.JEI.24.1.013003
URL : https://hal.archives-ouvertes.fr/hal-01116309
Dynamic Thermal Deformation Measurement of Large-Scale, High-Temperature Piping in Thermal Power Plants Utilizing the Sampling Moir?? Method and Grating Magnets, Experimental Mechanics, vol.72, issue.1, pp.1635-1646, 2013. ,
DOI : 10.1007/s11340-013-9761-2
Phase-stepped deflectometry applied to shape measurement of bent plates, Experimental Mechanics, vol.33, issue.27, pp.66-70, 1999. ,
DOI : 10.1007/BF02329303
A Procedure for Producing Reflective Coatings on Plates to be Used for Full-Field Slope Measurements by a Deflectometry Technique, Strain, vol.34, issue.2, pp.138-143, 2007. ,
DOI : 10.1111/j.1475-1305.2007.00324.x
DIRECT IDENTIFICATION OF ELASTIC CONSTANTS OF ANISOTROPIC PLATES BY MODAL ANALYSIS: EXPERIMENTAL RESULTS, Journal of Sound and Vibration, vol.210, issue.5, pp.645-659, 1998. ,
DOI : 10.1006/jsvi.1997.1304
Direct Measurement of Invariant Mechanical Parameters of Composite Plates, Journal of Composite Materials, vol.33, issue.21, pp.1939-1965, 1999. ,
DOI : 10.1177/002199839903302104
Impact damage detection in composite plates using deflectometry and the Virtual Fields Method, Composites Part A: Applied Science and Manufacturing, vol.48, pp.201-218, 2013. ,
DOI : 10.1016/j.compositesa.2013.01.011
Characterisation of the bending stiffness components of MDF panels from full-field slope measurements, Wood Science and Technology, vol.42, issue.6, pp.423-441, 2013. ,
DOI : 10.1007/s00226-012-0507-6
Characterization of a cracked specimen with full-field measurements: direct determination of the crack tip and energy release rate calculation, International Journal of Fracture, vol.42, issue.4, pp.109-121, 2014. ,
DOI : 10.1007/s10704-013-9921-5
Studying the mechanical behavior of notched wood beams using full-field measurements, Engineering Structures, vol.113, issue.5, pp.277-286, 2016. ,
DOI : 10.1016/j.engstruct.2016.01.052
Investigation of martensitic microstructures in a monocrystalline Cu???Al???Be shape memory alloy with the grid method and infrared thermography, Mechanics of Materials, vol.45, issue.1, pp.34-51, 2012. ,
DOI : 10.1016/j.mechmat.2011.09.007
Applying the grid method and infrared thermography to investigate plastic deformation in aluminium multicrystal, Mechanics of Materials, vol.43, issue.11, pp.36-53, 2011. ,
Strain intermittency in shape-memory alloys, Physical Review B, vol.91, issue.17, p.91174111, 2015. ,
DOI : 10.1103/PhysRevB.91.174111
Studying the Mechanical Behaviour of Asphalt Mixture with the Grid Method, Strain, vol.28, issue.1, pp.1-15, 2013. ,
DOI : 10.1111/str.12006
A comparative study of the heterogeneous local mechanical response of two types of asphalt mixes, Materials and Structures, vol.36, issue.11, pp.1513-1529, 2014. ,
DOI : 10.1617/s11527-013-0132-3
Studying the Influence of the Reclaimed Asphalt Pavement (RAP) on Local Deformation Properties of Asphalt Mixtures, 2016. ,
Investigation of the Hydric Transfer Phenomenon in Wood at the Ring Scale with the Grid Method, SEM annual conference, 2015. ,
DOI : 10.1007/978-3-319-22449-7_9
Using Sampling Moir?? to Extract Displacement Information from X-Ray Images of Molten Salt Batteries, Proceedings of the 2014 Annual Conference on Experimental and Applied Mechanics Experimental Mechanics " of Conference proceedings of the Society for Experimental Mechanics series, pp.331-336, 2014. ,
DOI : 10.1007/978-3-319-06986-9_38
Measurement of the displacement field of dislocations to 0.03????? by electron microscopy, Nature, vol.50, issue.6937, pp.270-273, 2003. ,
DOI : 10.1088/0953-8984/12/49/334
Stress and strain around grain-boundary dislocations measured by high-resolution electron microscopy, Philosophical Magazine, vol.190, issue.29-31, pp.4641-4656, 2006. ,
DOI : 10.1038/33823
Experimental examination of displacement and strain fields in an edge dislocation core, Acta Materialia, vol.56, issue.11, pp.562570-2575, 2008. ,
DOI : 10.1016/j.actamat.2008.01.045
Effects of elastic anisotropy on strain distributions in decahedral gold nanoparticles, Nature Materials, vol.54, issue.2, pp.120-124, 2008. ,
DOI : 10.1038/nmat2083
Residual strain around a step edge of artificial Al???Si(111)-7??7 nanocluster, Applied Physics Letters, vol.87, issue.20, p.201908, 2004. ,
DOI : 10.1063/1.2130722
Nanoscale deformation analysis of a crack-tip in silicon by geometric phase analysis and numerical moir?? method, Optics and Lasers in Engineering, vol.48, issue.11, pp.1104-1107, 2010. ,
DOI : 10.1016/j.optlaseng.2009.12.010
In-situ SEM investigation of sub-microscale deformation fields around a crack-tip in silicon, Optics and Lasers in Engineering, vol.50, issue.12, pp.501694-1698, 2012. ,
DOI : 10.1016/j.optlaseng.2012.07.017
Quantitative measurement of deformation field around low-angle grain boundaries by electron microscopy, Physica B: Condensed Matter, vol.403, issue.10-11, pp.10-111838, 2008. ,
DOI : 10.1016/j.physb.2007.10.157
Direct Mapping of Strain in a Strained Silicon Transistor by High-Resolution Electron Microscopy, Physical Review Letters, vol.100, issue.15, p.156602, 2008. ,
DOI : 10.1103/PhysRevLett.100.156602
Strain mapping in nanowires, Nanotechnology, vol.16, issue.10, pp.2365-2371, 2005. ,
DOI : 10.1088/0957-4484/16/10/062
The digital geometric phase technique applied to the deformation evaluation of MEMS devices, Journal of Micromechanics and Microengineering, vol.19, issue.1, p.15012, 2009. ,
DOI : 10.1088/0960-1317/19/1/015012
Characterization of cover-plate bolted steel joints with full-field measurements Experimental Mechanics Spanning Multiple Scientific and Engineering Disciplines, SEM annual conference Proceedings of the conference, 2015. ,
Overview of Identification Methods of Mechanical Parameters Based on Full-field Measurements, Experimental Mechanics, vol.48, issue.4, pp.381-402, 2008. ,
DOI : 10.1007/s11340-008-9148-y
URL : https://hal.archives-ouvertes.fr/hal-00274639
Novel experimental approach for longitudinal-radial stiffness characterisation of clear wood by a single test, Holzforschung, vol.61, issue.5, pp.61573-581, 2007. ,
DOI : 10.1515/HF.2007.083
URL : https://hal.archives-ouvertes.fr/emse-00499389
Variation of transverse and shear stiffness properties of wood in a tree, Composites Part A: Applied Science and Manufacturing, vol.40, issue.12, pp.1953-1960, 2009. ,
DOI : 10.1016/j.compositesa.2009.09.023
URL : https://hal.archives-ouvertes.fr/emse-00508396
Novel procedure for complete in-plane composite characterization using a single T-shaped specimen, Experimental Mechanics, vol.36, issue.1, pp.142-149, 1999. ,
DOI : 10.1007/BF02331118
Identification of the through-thickness rigidities of a thick laminated composite tube, Composites Part A: Applied Science and Manufacturing, vol.37, issue.2, pp.326-336, 2006. ,
DOI : 10.1016/j.compositesa.2005.05.050
Experimental identification of a nonlinear model for composites using the grid technique coupled to the virtual fields method, Composites Part A: Applied Science and Manufacturing, vol.37, issue.2, pp.315-325, 2006. ,
DOI : 10.1016/j.compositesa.2005.04.020
URL : https://hal.archives-ouvertes.fr/emse-00505330
Full-field assessment of the damage process of laminated composite open-hole tensile specimens. Part II: Experimental results, Composites Part A: Applied Science and Manufacturing, vol.38, issue.11, pp.382321-2332, 2007. ,
DOI : 10.1016/j.compositesa.2007.01.019
Identification of Elasto-Plastic Constitutive Parameters from Statically Undetermined Tests Using the Virtual Fields Method, Experimental Mechanics, vol.36, issue.2, pp.735-755, 2006. ,
DOI : 10.1007/s11340-006-9822-x
URL : https://hal.archives-ouvertes.fr/emse-00506126
Extension of the virtual fields method to elasto-plastic material identification with cyclic loads and kinematic hardening, International Journal of Solids and Structures, vol.47, issue.22-23, pp.22-232993, 2010. ,
DOI : 10.1016/j.ijsolstr.2010.06.022
URL : https://hal.archives-ouvertes.fr/emse-00579397
Full-field evaluation of the onset of microplasticity in a steel specimen, Mechanics of Materials, vol.41, issue.11, pp.1207-1222, 2009. ,
DOI : 10.1016/j.mechmat.2009.07.002
URL : https://hal.archives-ouvertes.fr/hal-00915636
storage image sensor ultra-high speed camera for full-field deformation measurements, Measurement Science and Technology, vol.25, issue.2, p.25401, 2014. ,
DOI : 10.1088/0957-0233/25/2/025401
Full-Field Strain Measurement and Identification of Composites Moduli at High Strain Rate with the Virtual Fields Method, Experimental Mechanics, vol.48, issue.4, pp.509-536, 2011. ,
DOI : 10.1007/s11340-010-9433-4
URL : https://hal.archives-ouvertes.fr/hal-01064631
Ultra-High-Speed Full-Field Deformation Measurements on Concrete Spalling Specimens and Stiffness Identification with the Virtual Fields Method, Strain, vol.23, issue.5, pp.388-405, 2012. ,
DOI : 10.1111/j.1475-1305.2012.00835.x
Beyond Hopkinson's bar, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.49, issue.5232, p.20130195, 2014. ,
DOI : 10.1126/science.7569924
Identification of the dynamic properties of Al 5456 FSW welds using the virtual fields method, Journal of Dynamic Behavior of Materials, 2015. ,
