Dynamic and Static Approaches Comparison for Test Suite Reduction in Industry
Automatic testing constitutes an important part in everyday development practice. IT companies are creating more and more tests to ensure the good behaviour of their applications and gain in efficiency and quality. But running all these tests consumes developer time (hours). This is especially true for the use of large systems involving, for example, the deployment of a web server, or the communication with a database. For this reason tests are not launched as often as they should. Reducing this testing time is a main concern for developers in order to get quick feedback after a change. An interesting solution is to reduce the number of tests to run by identifying those exercising the piece of code changed. Two main approaches seem to be distinguished in the literature: the static and the dynamic. The static approach creates a model of the system and explores it to find the links between the changed methods and the tests. The dynamic approach records the invocations of methods during the execution of test scenarios. We experimented these approaches on several industrial, closed source, cases to understand the strengths and weaknesses of each solution.
