On Homogeneous Distributed Parameter Systems
A geometric homogeneity is introduced for evolution equations in a Banach space. Scalability property of solutions of homogeneous evolution equations is proven. Some qualitative characteristics of stability of trivial solution are also provided. In particular, finite-time stability of homogeneous evolution equations is studied. Theoretical results are illustrated on important classes of partial differential equations.
Automatique
