Differential representations for mesh processing, Computer Graphics Forum, vol.25, issue.4, pp.789-807, 2006. ,
Spectral geometry processing. SIGGRAPH Asia Course Notes, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00432422
Spectral mesh processing, Computer Graphics Forum, vol.29, issue.6, pp.1865-94, 2010. ,
Laplacian matrices of graphs: a survey, Linear Algebra and its Applications, pp.143-76, 1994. ,
Fundamentals of image processing, 1998. ,
High-quality streamable free-viewpoint video, Transactions on Graphics, vol.34, issue.4, pp.69-70, 2015. ,
Discrete exterior calculus, 2005. ,
Digital geometry processing with discrete exterior calculus. SIGGRAPH Course Notes, 2013. ,
Computing discrete minimal surfaces and their conjugates, Experimental Mathematics, vol.2, issue.1, pp.15-36, 1993. ,
A signal processing approach to fair surface design, SIG-GRAPH, pp.351-359, 1995. ,
Discrete differentialgeometry operators for triangulated 2-manifolds, Visualization and mathematics III, pp.35-57, 2003. ,
, Zoom on frames 5 to 11 showing that results using Tejera et al. [39] (left) and our method with ? = 0.01 (right) are visually similar
, First two rows: performing a higher kick, Figure, vol.9
A discrete Laplace-Beltrami operator for simplicial surfaces, Discrete and Computational Geometry, vol.38, issue.4, pp.740-56, 2007. ,
Discrete Laplacians on general polygonal meshes, Transactions on Graphics, vol.30, issue.4, pp.1-10, 2011. ,
Constructing laplace operator from point clouds in Rd, Symposium on Discrete Algorithms, pp.1031-1071, 2009. ,
Point-based manifold harmonics, Transactions on Visualization and Computer Graphics, vol.18, issue.10, pp.1693-703, 2012. ,
Meshfree discrete Laplace-Beltrami operator, Computer Graphics Forum, vol.32, issue.6, pp.214-240, 2013. ,
Large mesh deformation using the volumetric graph laplacian, Transactions on Graphics, vol.24, issue.3, pp.496-503, 2005. ,
Laplacians on discrete and quantum geometries, Classical and Quantum Gravity, vol.30, issue.12, pp.125006-125007, 2013. ,
Discretizing LaplaceBeltrami operator from differential quantities, Communications in Mathematics and Statistics, vol.1, issue.3, pp.331-50, 2013. ,
Consistent approximations of several geometric differential operators and their convergence, Applied Numerical Mathematics, vol.69, pp.1-12, 2013. ,
Spatio-temporal coupling with the 3d+t motion Laplacian, Computer Animation and Virtual Worlds, vol.24, issue.3-4, pp.419-447, 2013. ,
Multi-scale geometric detail enhancement for time-varying surfaces, Graphical Models, vol.76, issue.5, pp.413-438, 2014. ,
An efficient volumetric framework for shape tracking, Conference on Computer Vision and Pattern Recognition, pp.268-76, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01141207
Algebraic topology, 2002. ,
Discrete exterior calculus. Ph.D. thesis; Caltech, 2003. ,
Discrete calculus: applied analysis on graphs for computational science, 2010. ,
Spectral geometry processing with manifold harmonics, Computer Graphics Forum, vol.27, issue.2, pp.251-60, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00186931
A fast parallel algorithm for solving block-tridiagonal systems of linear equations including the domain decomposition method, Parallel Computing, vol.39, issue.6, pp.245-58, 2013. ,
A review on the inverse of symmetric tridiagonal and block tridiagonal matrices, Journal on Matrix Analysis and Applications, vol.13, issue.3, pp.707-735, 1992. ,
A note on a three-term recurrence for a triadiagonal matrix, Applied Mathematics and Computation, vol.176, issue.2, pp.442-446, 2006. ,
Determinants of block tridiagonal matrices, Linear Algebra and its Applications, vol.429, issue.8-9, pp.2221-2227, 2008. ,
Spatial relationship preserving character motion adaptation, Transactions on Graphics, vol.29, issue.4, pp.33-34, 2010. ,
Editing arbitrarily deforming surface animations, Transactions on Graphics, vol.25, issue.3, pp.1098-107, 2006. ,
Free-form motion processing, Transactions on Graphics, vol.27, issue.2, pp.1-13, 2008. ,
Gradient domain editing of deforming mesh sequences, Transactions on Graphics, vol.26, issue.3, pp.1-10, 2007. ,
As-rigid-as-possible surface modeling, Symposium on Geometry Processing, pp.109-125, 2007. ,
Embedded deformation for shape manipulation, Transactions on Graphics, vol.26, issue.3, pp.1-8, 2007. ,
Representing and manipulating mesh-based character animations, SIBGRAPI Conference on Graphics, Patterns and Images, pp.198-204, 2012. ,
Animation control of surface motion capture, Transactions on Cybernetics, vol.43, issue.6, pp.1532-1577, 2013. ,
Laplacian surface editing, Symposium on Geometry Processing, pp.175-84, 2004. ,
Dual Laplacian editing for meshes, Transaction on Visualization and Computer Graphics, vol.12, issue.3, pp.386-95, 2006. ,
Smooth rotation enhanced as-rigid-as-possible mesh animation, Transactions on Visualization and Computer Graphics, vol.21, issue.2, pp.264-77, 2015. ,
Algorithm 887: Cholmod, supernodal sparse cholesky factorization and update/downdate, Transactions on Mathematical Software, vol.35, issue.3, pp.1-14, 2008. ,
Deformation transfer for triangle meshes, Transactions on Graphics, vol.23, issue.3, pp.399-405, 2004. ,
Surface capture for performance-based animation, Computer Graphics and Applications, vol.27, issue.3, pp.21-31, 2007. ,
Performance capture from sparse multi-view video, Transactions on Graphics, vol.27, issue.3, pp.1-10, 2008. ,
