On the Behaviour of the (1,??)-??SA-ES for a Constrained Linear Problem, Parallel Problem Solving from Nature, PPSN XII, pp.82-91, 2012. ,
DOI : 10.1007/978-3-642-32937-1_9
On the Behaviour of the (1+1)-ES for a Simple Constrained Problem, Parallel Problem Solving from Nature, PPSN X, pp.1-10, 2008. ,
DOI : 10.1007/978-3-540-87700-4_1
Towards au Augmented Lagrangian Constraint Handling Approach for the (1 + 1)-ES, Genetic and Evolutionary Computation Conference, pp.249-256, 2015. ,
Convergence results for the <mml:math altimg="si1.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mo stretchy="false">(</mml:mo><mml:mn>1</mml:mn><mml:mo>,</mml:mo><mml:mi>??</mml:mi><mml:mo stretchy="false">)</mml:mo></mml:math>-SA-ES using the theory of <mml:math altimg="si2.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math>-irreducible Markov chains, Theoretical Computer Science, vol.334, issue.1-3, pp.35-69, 2005. ,
DOI : 10.1016/j.tcs.2004.11.017
Linear Convergence of Comparison-based Step-size Adaptive Randomized Search via Stability of Markov Chains, SIAM Journal on Optimization, vol.26, issue.3, 2013. ,
DOI : 10.1137/140984038
URL : https://hal.archives-ouvertes.fr/hal-00877160
Linear Convergence on Positively Homogeneous Functions of a Comparison Based Step-Size Adaptive Randomized Search: the (1 + 1) ES with Generalized One-Fifth Success Rule, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877161
Verifiable Conditions for Irreducibility, Aperiodicity and T-chain Property of a General Markov Chain, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01222222
Multiplier and gradient methods, Journal of Optimization Theory and Applications, vol.4, issue.5, pp.303-320, 1969. ,
DOI : 10.1007/BF00927673
Learning probability distributions in continuous evolutionary algorithms ??? a comparative review, Natural Computing, vol.3, issue.1, pp.77-112, 2004. ,
DOI : 10.1023/B:NACO.0000023416.59689.4e
Markov Chains and Stochastic Stability, 1993. ,
Numerical Optimization, 2006. ,
DOI : 10.1007/b98874
A Method for Nonlinear Constraints in Minimization Problems, pp.283-298, 1969. ,
