New interface
Conference papers
Automated generation of BSP automata
Abstract : Bulk-Synchronous Parallel (BSP) is a bridging model between abstract execution and concrete parallel architecture. In order to model BSP program executions Hains adapted the finite automata theory to the BSP paradigm by introducing BSP automata theory. Benefit provided by BSP automata is twofold: modeling BSP program control and parallelizing finite state automata. The lack of generation algorithm of BSP automata and the illusory lack of application of this theory has been preventing this theory from being used. We propose in this paper an algorithm that generates a BSP automaton recognizing a defined BSP language. In order to demonstrate the usefulness of BSP automata and help to design its use, two applications of the BSP automata theory are provided. The parallel recognition of an expression and debugging of a BSP program.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01319565
Contributor : Frédéric Loulergue Connect in order to contact the contributor
Submitted on : Friday, May 20, 2016 - 8:15:54 PM
Last modification on : Friday, October 7, 2022 - 4:52:07 PM
Identifiers
  • HAL Id : hal-01319565, version 1
Citation
Thibaut Tachon, Gaétan Hains, Frédéric Loulergue, Chong Li. Automated generation of BSP automata. High Level Parallel Programming and Applications (HLPP), Jul 2016, Münster, Germany. ⟨hal-01319565⟩
Share
Metrics
Record views
113
