Bit complexity for multi-homogeneous polynomial system solving Application to polynomial minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Mohab Safey El Din
Multi-homogeneous polynomial systems arise in many applications. We provide bit complexity estimates for solving them which, up to a few extra other factors, are quadratic in the number of solutions and linear in the height of the input system under some genericity assumptions. The assumptions essentially imply that the Jacobian matrix of the system under study has maximal rank at the solution set and that this solution set if finite. The algorithm is probabilistic and a probability analysis is provided. Next, we apply these results to the problem of optimizing a linear map on the real trace of an algebraic set. Under some genericity assumptions, we provide bit complexity estimates for solving this polynomial minimization problem.
bit-multi-homo.pdf (387.67 Ko) Télécharger le fichier
hal-01319729 , version 1 (22-05-2016)
hal-01319729 , version 2 (09-12-2017)
Mohab Safey El Din, Eric Schost. Bit complexity for multi-homogeneous polynomial system solving Application to polynomial minimization. 2016. ⟨hal-01319729v1⟩
261 Consultations
717 Téléchargements
