New interface
Journal articles
Bit complexity for multi-homogeneous polynomial system solving Application to polynomial minimization
Abstract : Multi-homogeneous polynomial systems arise in many applications. We provide bit complexity estimates for solving them which, up to a few extra other factors, are quadratic in the number of solutions and linear in the height of the input system under some genericity assumptions. The assumptions essentially imply that the Jacobian matrix of the system under study has maximal rank at the solution set and that this solution set if finite. The algorithm is probabilistic and a probability analysis is provided. Next, we apply these results to the problem of optimizing a linear map on the real trace of an algebraic set. Under some genericity assumptions, we provide bit complexity estimates for solving this polynomial minimization problem.
Document type :
Journal articles
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/hal-01319729
Contributor : Mohab Safey El Din Connect in order to contact the contributor
Submitted on : Saturday, December 9, 2017 - 12:57:41 PM
Last modification on : Friday, July 8, 2022 - 10:06:53 AM
Long-term archiving on: : Saturday, March 10, 2018 - 12:24:25 PM
bit-multi-homo.pdf
Identifiers
Citation
Mohab Safey El Din, Éric Schost. Bit complexity for multi-homogeneous polynomial system solving Application to polynomial minimization. Journal of Symbolic Computation, In press, 87, pp.176-206. ⟨10.1016/j.jsc.2017.08.001⟩. ⟨hal-01319729v2⟩
Share
Metrics
Record views
235
Files downloads
666
