Simple Distributed Scheduling with Collision Detection in TSCH Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Sensors Letters Année : 2016
The IETF IPv6 over the Time Synchronized Channel Hopping mode of IEEE 802.15.4e (6TiSCH) working group standardizes a distributed mechanism for neighbor motes to agree on a schedule to communicate, driven by a Scheduling Function. This letter introduces the notion of “housekeeping” to the Schedule Function, in which motes relocate cells in the schedule to build a collision-free schedule in a distribute manner. The solution, based on detecting under-performing cells and listening for unexpected packets, does not require additional signaling traffic or state. This letter shows that simple housekeeping rules introduced allow a network to contain 17% more motes and suffer from 64% fewer collision, while maintaining end-to-end reliability above 99.5% in a typical industrial environment. This solution is now being discussed for standardization at 6TiSCH.
muraoka16simple.pdf (851.14 Ko) Télécharger le fichier
hal-01319765 , version 1 (07-01-2020)
  • HAL Id : hal-01319765 , version 1
Kazuki Muraoka, Thomas Watteyne, Nicola Accettura, Xavier Vilajosana, Kristofer Pister. Simple Distributed Scheduling with Collision Detection in TSCH Networks. IEEE Sensors Letters, 2016. ⟨hal-01319765⟩
160 Consultations
241 Téléchargements
