Examining Usability Work and Culture in OSS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mikko Rajanen
  • Fonction : Auteur
  • PersonId : 982514
Netta Iivari
  • Fonction : Auteur
  • PersonId : 982515
Organizational culture has been recognized as an influential factor affecting the successes and failures of usability work in organizations; however, there is a lack of research on organizational culture in open source software (OSS) development. This paper shows that there are different kinds of cultures in OSS development projects and builds propositions on the relationship between culture and usability work in OSS development projects. Partly those are derived from the literature, partly from an exploratory empirical inquiry. We speculate whether there is an ideal culture type for usability work in OSS development or whether usability work should be modified to fit the different cultures of OSS development projects.
337452_1_En_6_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01320160 , version 1 (23-05-2016)
Paternité
Mikko Rajanen, Netta Iivari. Examining Usability Work and Culture in OSS. 11th International Conference on Open Source Systems (OSS), May 2015, Florence, Italy. pp.58-67, ⟨10.1007/978-3-319-17837-0_6⟩. ⟨hal-01320160⟩
56 Consultations
93 Téléchargements
