First Results About Motivation and Impact of License Changes in Open Source Projects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Free and open source software is characterized by the freedoms and criteria that are warranted by specific licenses. These licenses describe the rights and duties of the licensors and licensees. However, a licensing change may be necessary in the life of an open source project to meet legal developments or to allow the implementation of new business models. This paper examines the motivations and impacts of license changes in open source projects. After a state of the art on the subject, a set of case studies where projects changed their license is presented. Then a set of motivations to change licenses, the ways to legally make this change, the problems caused by this change and a set of benefits of the license change are discussed.
337452_1_En_13_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01320180 , version 1 (23-05-2016)
Paternité
Robert Viseur, Gregorio Robles. First Results About Motivation and Impact of License Changes in Open Source Projects. 11th International Conference on Open Source Systems (OSS), May 2015, Florence, Italy. pp.137-145, ⟨10.1007/978-3-319-17837-0_13⟩. ⟨hal-01320180⟩
154 Consultations
200 Téléchargements
