Computing cardinalities of Q-curve reductions over finite fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We present a specialized point-counting algorithm for a class of elliptic curves over F_{p^2} that includes reductions of quadratic Q-curves modulo inert primes and, more generally, any elliptic curve over F_{p^2} with a low-degree isogeny to its Galois conjugate curve. These curves have interesting cryptographic applications. Our algorithm is a variant of the Schoof–Elkies–Atkin (SEA) algorithm, but with a new, lower-degree endomorphism in place of Frobenius. While it has the same asymptotic asymptotic complexity as SEA, our algorithm is much faster in practice.
qcsea.pdf (221.06 Ko) Télécharger le fichier
hal-01320388 , version 1 (23-05-2016)
hal-01320388 , version 2 (06-06-2016)
hal-01320388 , version 3 (17-06-2016)
François Morain, Charlotte Scribot, Benjamin Smith. Computing cardinalities of Q-curve reductions over finite fields. 2016. ⟨hal-01320388v1⟩
396 Consultations
217 Téléchargements
