Eshelby inclusions in granular matter: theory and simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E Année : 2016
Sean Mcnamara
Jérôme Crassous
Axelle Amon
We present a numerical implementation of an active inclusion in a granular material submitted to a biaxial test. We discuss the dependence of the response to this perturbation on two parameters: the intra-granular friction coefficient on one hand, the degree of the loading on the other hand. We compare the numerical results to theoretical predictions taking into account the change of volume of the inclusion as well as the anisotropy of the elastic matrix.
pre_eshelby_v2.pdf (868 Ko) Télécharger le fichier
hal-01321159 , version 1 (25-05-2016)
hal-01321159 , version 2 (26-08-2016)
Sean Mcnamara, Jérôme Crassous, Axelle Amon. Eshelby inclusions in granular matter: theory and simulations. Physical Review E , 2016, 94 (2), pp.022907. ⟨10.1103/PhysRevE.94.022907⟩. ⟨hal-01321159v2⟩
147 Consultations
467 Téléchargements
