A method of bivariate interpolation and smooth surface fitting based on local procedures, Communications of the ACM, vol.17, issue.1, pp.18-20, 1974. ,
DOI : 10.1145/360767.360779
On the solution of the magnetic flux equation in an infinite domain, EPS. 8th Europhysics Conference on Computing in Plasma Physics, pp.41-44, 1986. ,
A refined triangular plate bending finite element, International Journal for Numerical Methods in Engineering, vol.93, issue.1, pp.101-122, 1969. ,
DOI : 10.1002/nme.1620010108
On a free boundary problem arising in plasma physics, Nonlinear Analysis: Theory, Methods & Applications, vol.4, issue.3, pp.415-436, 1980. ,
DOI : 10.1016/0362-546X(80)90083-8
A new nonconforming approach to domain decomposition: the mortar element method In Nonlinear partial differential equations and their applications, Colì ege de France Seminar Pitman Res. Notes Math. Ser., Longman Sci. Tech, vol.299, pp.13-51, 1989. ,
A novel approach to magnetic divertor configuration design, Journal of Nuclear Materials, vol.463, pp.463-1220, 2015. ,
DOI : 10.1016/j.jnucmat.2014.11.053
Towards Automated Magnetic Divertor Design for Optimal Heat Exhaust, ESAIM: Proceedings and Surveys, vol.53, pp.53-102, 2016. ,
DOI : 10.1051/proc/201653004
URL : https://hal.archives-ouvertes.fr/hal-01389537
Numerical simulation and optimal control in plasma physics, 1989. ,
Existence and Control of Plasma Equilibrium in a Tokamak, SIAM Journal on Mathematical Analysis, vol.17, issue.5, pp.1158-1177, 1986. ,
DOI : 10.1137/0517081
Plasma equilibrium evolution at the resistive diffusion timescale, Computer Physics Reports, vol.1, issue.7-8, pp.7-8, 1984. ,
DOI : 10.1016/0167-7977(84)90013-3
The self-consistent equilibrium and diffusion code sced, Computer Physics Communications, vol.24, issue.3-4, pp.235-254, 1981. ,
DOI : 10.1016/0010-4655(81)90149-1
The generation of interelement compatible stiffness and mass matrices by the use of interpolation formulas, Proceedings of the Conference on Matrix Methods in Structural Mechanics, 1965. ,
Overlapping Nonmatching Grid Mortar Element Methods for Elliptic Problems, SIAM Journal on Numerical Analysis, vol.36, issue.2, pp.581-606, 1999. ,
DOI : 10.1137/S0036142997323582
Programming of finite element methods in Matlab, 2011. ,
A mortar element approach on overlapping nonnested grids: application to eddy current non-destructive testing, Appl. Math. Comput, vol.267, pp.71-82, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01254684
The Finite Element Method for Elliptic Problems, Studies in Mathematics and its Applications, 1978. ,
An efficient way to assemble finite element matrices in vector languages, BIT Numerical Mathematics, vol.219, issue.13, pp.833-864, 2016. ,
DOI : 10.1007/s10543-015-0587-4
URL : https://hal.archives-ouvertes.fr/hal-00931066
Shapes and geometries, volume 22 of Advances in Design and Control, Society for Industrial and Applied Mathematics (SIAM), 2011. ,
Computing with hp-adaptive finite elements One and two dimensional elliptic and Maxwell problems, CRC Applied Mathematics and Nonlinear Science Series. Chapman & Hall/CRC, vol.1, p.1, 2007. ,
A domain decomposition method on nested domains and nonmatching grids, Numerical Methods for Partial Differential Equations, vol.38, issue.3, pp.374-387, 2004. ,
DOI : 10.1002/num.10095
The Uncoupling of Boundary Integral and Finite Element Methods for Nonlinear Boundary Value Problems, Journal of Mathematical Analysis and Applications, vol.189, issue.2, pp.442-461, 1995. ,
DOI : 10.1006/jmaa.1995.1029
Advanced magnetohydrodynamics: with applications to laboratory and astrophysical plasmas, 2010. ,
DOI : 10.1017/CBO9781139195560
Principles of magnetohydrodynamics: with applications to laboratory and astrophysical plasmas, 2004. ,
DOI : 10.1017/CBO9780511616945
Conformal mapping methods in two-dimensional magnetohydrodynamics, Computer Physics Communications, vol.24, issue.3-4, pp.3-4, 1981. ,
DOI : 10.1016/0010-4655(81)90153-3
Classical Diffusion in a Tokomak, Physical Review Letters, vol.24, issue.24, pp.1337-1340, 1970. ,
DOI : 10.1103/PhysRevLett.24.1337
Hydromagnetic equilibria and force-free fields, Proceedings of the 2nd UN Conf. on the Peaceful Uses of Atomic Energy, pp.190-197, 1958. ,
DOI : 10.1016/0891-3919(58)90139-6
Modélisation de l'´ equilibre d'un plasma de tokamak, 1999. ,
Axisymmetric eddy current inspection of highly conducting thin layers via asymptotic models, Inverse Problems, vol.31, issue.11, pp.1-25, 2015. ,
DOI : 10.1088/0266-5611/31/11/115005
URL : https://hal.archives-ouvertes.fr/hal-01214308
Artificial boundary conditions for axisymmetric eddy current probe problems, Computers & Mathematics with Applications, vol.68, issue.12, pp.1844-1870, 2014. ,
DOI : 10.1016/j.camwa.2014.10.008
URL : https://hal.archives-ouvertes.fr/hal-01072091
Numerical Zoom and the Schwarz Algorithm, Lect. Notes Comput. Sci. Eng, vol.70, pp.63-73, 2009. ,
DOI : 10.1007/978-3-642-02677-5_6
URL : https://hal.archives-ouvertes.fr/hal-00628622
Quasi-static free-boundary equilibrium of toroidal plasma with CEDRES++: Computational methods and applications, Journal of Plasma Physics, vol.6, issue.03, pp.1-35, 2015. ,
DOI : 10.1016/j.fusengdes.2011.03.092
URL : https://hal.archives-ouvertes.fr/hal-01088772
Simulation technique of free-boundary equilibrium evolution in plasma ramp-up phase, Computer Physics Communications, vol.181, issue.9, pp.1490-1500, 2010. ,
DOI : 10.1016/j.cpc.2010.04.014
Solving the Grad???Shafranov equation with spectral elements, Computer Physics Communications, vol.185, issue.5, pp.1415-1421, 2014. ,
DOI : 10.1016/j.cpc.2014.02.008
Isoparametric Bicubic Hermite Elements for Solution of the Grad-Shafranov Equation, Proc. CP90 Conf. on Comp. Phys, pp.371-372, 1991. ,
DOI : 10.1142/S0129183191000512
A triangular finite element with first-derivative continuity applied to fusion MHD applications, Journal of Computational Physics, vol.200, issue.1, pp.133-152, 2004. ,
DOI : 10.1016/j.jcp.2004.04.004
Computational methods in plasma physics, 2010. ,
DOI : 10.1201/EBK1439810958
Spectral/hp element methods for computational fluid dynamics. Numerical Mathematics and Scientific Computation, 2005. ,
Studies of Plasma Equilibrium and Transport in a Tokamak Fusion Device with the Inverse-Variable Technique, Journal of Computational Physics, vol.109, issue.2, pp.193-201, 1993. ,
DOI : 10.1006/jcph.1993.1211
Vectorized matlab codes for linear two-dimensional elasticity. Sci. Program, pp.157-172, 2007. ,
Overlapping domain decomposition with non-matching grids In Recent developments in domain decomposition methods and flow problems, GAKUTO Internat. Ser. Math. Sci. Appl. Gakk¯ otosho, vol.11, pp.62-71, 1996. ,
Axialsymmetrische magnetohydrodynamische Gleichgewichtskonfigurationen, Zeitschrift f??r Naturforschung A, vol.12, issue.10, pp.850-854, 1957. ,
DOI : 10.1515/zna-1957-1014
Magnetic analysis of non-circular cross-section tokamaks, Nuclear Fusion, vol.22, issue.6, pp.813-821, 1982. ,
DOI : 10.1088/0029-5515/22/6/009
Axisymmetric MHD equilibrium solver with bicubic Hermite elements, Computer Physics Communications, vol.69, issue.2-3, pp.287-298, 1992. ,
DOI : 10.1016/0010-4655(92)90167-W
Sur le contrôle par un domaine géométrique, 1976. ,
On an equilibrium of the plasma in a Tokamak with a limiter, Japan Journal of Industrial and Applied Mathematics, vol.2, issue.3, pp.431-444, 1991. ,
DOI : 10.1007/BF03167145
Numerical optimization. Springer Series in Operations Research and Financial Engineering, 2006. ,
A mimetic spectral element solver for the gradshafranov equation, J. of Comput. Phys, pp.316-63, 2016. ,
A fast, high-order solver for the Grad???Shafranov equation, Journal of Computational Physics, vol.243, issue.0, pp.28-45, 2013. ,
DOI : 10.1016/j.jcp.2013.02.045
Monotonicity-preserving interproximation of B???H-curves, Journal of Computational and Applied Mathematics, vol.196, issue.1, pp.45-57, 2006. ,
DOI : 10.1016/j.cam.2005.08.021
Geometrical properties of a ???snowflake??? divertor, Physics of Plasmas, vol.14, issue.6, p.14, 2007. ,
DOI : 10.1063/1.2738399
p-and hp-finite element methods : theory and applications in solid and fluid mechanics, 2004. ,
On magnetohydrodynamical equilibrium configurations, Soviet Journal of Experimental and Theoretical Physics, vol.6, p.545, 1958. ,
Use of the virtual-casing principle in calculating the containing magnetic field in toroidal plasma systems, Nuclear Fusion, vol.12, issue.5, pp.599-601, 1972. ,
DOI : 10.1088/0029-5515/12/5/009
Remarks on a free Boundary Value Problem Arising in Plasma Physics, Communications in Partial Differential Equations, vol.51, issue.6, pp.563-585, 1977. ,
DOI : 10.1007/BF00281469
The mortar element method for the free-boundary toroidal plasma equilibrium problem, Erasmus Mundus Joint Master Degree in Mathematical Modeling in Engineering MATHMODS, 2016. ,
Tokamaks. The International Series of Monographs in Physics, 2004. ,
Discretization methods and iterative solvers based on domain decomposition, Lecture Notes in Computational Science and Engineering, vol.17, 2001. ,
DOI : 10.1007/978-3-642-56767-4
The numerical solution of the self-consistent evolution of plasma equilibria, Computer Physics Communications, vol.157, issue.2, pp.107-120, 2004. ,
DOI : 10.1016/S0010-4655(03)00495-8
