Abstract : Sensitivity analysis w.r.t. the long-range/memory noise parameter for
probability distributions of functionals of solutions to stochastic
differential equations is an important stochastic modeling issue in
many applications.
In this paper we consider solutions $\{X^H_t\}_{t\in
\R_+}$ to stochastic differential equations driven
by frac{t}ional Brownian motions.
We develop two innovative sensitivity analyses
when the Hurst parameter~$H$ of the noise tends to the
critical Brownian parameter $H=\tfrac{1}{2}$ from above or from
below. First, we examine expected smooth functions of $X^H$ at a
fixed time horizon~$T$.
Second, we examine Laplace transforms of functionals which are
irregular with regard to Malliavin calculus, namely, first passage
times of $X^H$ at a given threshold.
In both cases we exhibit the Lipschitz continuity w.r.t.~$H$ around the
value $\tfrac{1}{2}$. Therefore, our results show that the
Markov Brownian model is a good proxy
model as long as the Hurst parameter remains close to~$\tfrac{1}{2}$.
