Relative pressure estimation from velocity measurements in blood flows: state-of-the-art and new approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Biomedical Engineering Année : 2017
The pressure gradient across stenotic blood vessels is an important clinical index for the diagnosis of many cardiovascular diseases. While clinical gold standard for its measurement (in terms of accuracy) is invasive catheterization, Phase-Contrast MR-imaging has emerged as a promising tool for enabling a non-invasive quantification, by linking (highly spatially resolved) velocity measurements with relative pressures via Navier-Stokes equations. In this work we provide a review of current methods for relative pressure estimation, propose new ones and compare them on numerical examples using subsampled and noisy synthetic data. We verify that the newly proposed approaches are more robust with respect to data perturbations and therefore more precise.
pressdrop_preprint_v2.pdf (887.32 Ko) Télécharger le fichier
hal-01323289 , version 1 (30-05-2016)
hal-01323289 , version 2 (15-06-2016)
Cristobal Bertoglio, Rodolfo Núñez, Felipe Galarce, David Nordsletten, Axel Osses. Relative pressure estimation from velocity measurements in blood flows: state-of-the-art and new approaches. International Journal for Numerical Methods in Biomedical Engineering, 2017, ⟨10.1002/cnm.2925⟩. ⟨hal-01323289v2⟩
Collections
TDS-MACS
505 Consultations
494 Téléchargements
