Ethical Issues in Corpus Linguistics And Annotation: Pay Per Hit Does Not Affect Effective Hourly Rate For Linguistic Resource Development On Amazon Mechanical Turk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ethical issues reported with paid crowdsourcing include unfairly low wages. It is assumed that such issues are under the control of the task requester. Can one control the amount that a worker earns by controlling the amount that one pays? 412 linguistic data development tasks were submitted to Amazon Mechanical Turk. The pay per HIT was manipulated through a range of values. We examined the relationship between the pay that is offered per HIT and the effective pay rate. There is no such relationship. Paying more per HIT does not cause workers to earn more: the higher the pay per HIT, the more time workers spend on them (R = 0.92). So, the effective hourly rate stays roughly the same. The finding has clear implications for language resource builders who want to behave ethically: other means must be found in order to compensate workers fairly. The findings of this paper should not be taken as an endorsement of unfairly low pay rates for crowdsourcing workers. Rather, the intention is to point out that additional measures, such as pre-calculating and communicating to the workers an average hourly, rather than per-task, rate must be found in order to ensure an ethical rate of pay.
Cohen ETHI-CA 2016.pdf (98.63 Ko) Télécharger le fichier
hal-01324362 , version 1 (31-05-2016)
  • HAL Id : hal-01324362 , version 1
K Bretonnel Cohen, Karën Fort, Gilles Adda, Sophia Zhou, Dimeji Farri. Ethical Issues in Corpus Linguistics And Annotation: Pay Per Hit Does Not Affect Effective Hourly Rate For Linguistic Resource Development On Amazon Mechanical Turk. ETHics In Corpus collection, Annotation and Application workshop, May 2016, Portoroz, Slovenia. ⟨hal-01324362⟩
255 Consultations
293 Téléchargements
