Optimal electrode diameter in relation to volume of the cochlea - Archive ouverte HAL Access content directly
Journal Articles European Annals of Otorhinolaryngology, Head and Neck Diseases Year : 2016
(1) , (1, 2) , (3) , (4) , (3) , (2) , (2)
1
2
3
4
The volume of the cochlea is a key parameter for electrode-array design. Indeed, it constrains the diameter of the electrode-array for low-traumatic positioning in the scala timpani. The present report shows a model of scala timpani volume extraction from temporal bones images in order to estimate a maximum diameter of an electrode-array. Nine temporal bones were used, and passed to high-resolution computed tomography scan. Using image-processing techniques, scala timpani were extracted from images, and cross-section areas were estimated along cochlear turns. Cochlear implant electrode-array was fitted in these cross-sections. Results show that the electrode-array diameter is small enough to fit in the scala timpani, however the diameter is restricted at the apical part.
ANORL.pdf (1.57 Mo) Télécharger le fichier
Dates and versions
hal-01326507 , version 1 (26-10-2016)
Identifiers
Cite
Dan Gnansia, Thomas Demarcy, Clair Vandersteen, Charles Raffaelli, Nicolas Guevara, et al.. Optimal electrode diameter in relation to volume of the cochlea. European Annals of Otorhinolaryngology, Head and Neck Diseases, 2016, 133, Supplement 1, pp.S66-S67. ⟨10.1016/j.anorl.2016.04.013⟩. ⟨hal-01326507⟩
Collections
INRIA INRIA2
144 View
145 Download
Share
