Strong minimality of abnormal geodesics for 2-distributions, Journal of Dynamical and Control Systems, vol.113, issue.2, pp.2-139, 1995. ,
DOI : 10.1007/BF02254637
Optimal Strokes for Low Reynolds Number Swimmers: An Example, Journal of Nonlinear Science, vol.209, issue.3, pp.277-302, 2008. ,
DOI : 10.1007/s00332-007-9013-7
The tangent space in sub-Riemannian geometry, J. Math. Sci, vol.4, pp.83-461, 1997. ,
La taxonomie des courbes, Pour la science, vol.297, pp.56-63, 2002. ,
The three links Purcell swimmer and some geometric problems related to periodic optimal controls, Rad. Ser. Comp. App. Variational Methods, vol.18, 2016. ,
Optimal control theory and the efficiency of the swimming mechanism of the Copepod Zooplankton ,
URL : https://hal.archives-ouvertes.fr/hal-01387423
Bocop -A collection of examples, Inria Research Report, p.8053, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00726992
Second order optimality conditions in the smooth case and applications in optimal control, ESAIM: Control, Optimisation and Calculus of Variations, vol.13, issue.2, pp.207-236, 2007. ,
DOI : 10.1051/cocv:2007012
URL : https://hal.archives-ouvertes.fr/hal-00086380
Singular trajectories and their role in control theory, Mathématiques & Applications, vol.40, 2003. ,
DOI : 10.1007/978-1-4471-5058-9_49
GEOMETRIC NUMERICAL METHODS AND RESULTS IN THE CONTRAST IMAGING PROBLEM IN NUCLEAR MAGNETIC RESONANCE, Mathematical Models and Methods in Applied Sciences, vol.24, issue.01, pp.5-45, 2015. ,
DOI : 10.1142/S0218202513500504
On the role of abnormal minimizers in sub-riemannian geometry, Annales de la facult?? des sciences de Toulouse Math??matiques, vol.10, issue.3, pp.10-405, 2001. ,
DOI : 10.5802/afst.998
URL : https://hal.archives-ouvertes.fr/hal-00086308
Les syst??mes de Pfaff, ?? cinq variables et les ??quations aux d??riv??es partielles du second ordre, Annales scientifiques de l'??cole normale sup??rieure, vol.27, pp.109-192, 1910. ,
DOI : 10.24033/asens.618
URL : http://archive.numdam.org/article/ASENS_1910_3_27__109_0.pdf
Small Subriemannian Balls on R 3, J. Dynam. Control Systems, vol.2, issue.3, pp.359-421, 1996. ,
Optimal strokes for driftless swimmers: A general geometric approach, ESAIM: Control, Optimisation and Calculus of Variations, 2014. ,
DOI : 10.1051/cocv/2017012
URL : https://hal.archives-ouvertes.fr/hal-00969259
Contrôle optimal géométrique : méthodes homotopiques et applications, 2012. ,
Second Order Sufficient Conditions for Optimal Control Problems with Non-unique Minimizers: An Abstract Framework, Applied Mathematics & Optimization, vol.40, issue.3, pp.411-442, 2014. ,
DOI : 10.1007/s00245-014-9245-5
Non-minimality of corners in sub-Riemannian geometry, 2015. ,
Low Reynolds number hydrodynamics with special applications to particulate media, N.J, 1965. ,
Controllability and Time Optimal Control for Low Reynolds Numbers Swimmers, Acta Applicandae Mathematicae, vol.209, issue.1, pp.175-200, 2013. ,
DOI : 10.1007/s10440-012-9760-9
Introduction to Hamiltonian dynamical systems and the N -body problem, 1992. ,
DOI : 10.1007/978-1-4757-4073-8
A tour of subriemannian geometries, their geodesics and applications, p.91, 2002. ,
DOI : 10.1090/surv/091
Supplementary notes to: Dynamics of Purcells three-link microswimmer with a passive elastic tail, EPJ E, vol.35, pp.1-9, 2012. ,
The mathematical theory of optimal processes, 1962. ,
Life at low Reynolds number, American Journal of Physics, vol.45, issue.1, pp.3-11, 1977. ,
DOI : 10.1119/1.10903
Symmetries of flat rank two distributions and sub-Riemannian structures, Trans. Amer. Math. Soc. n, vol.2, pp.356-457, 2004. ,
Swimming with stiff legs at low Reynolds number, Physical Review E, vol.92, issue.2, 2015. ,
DOI : 10.1103/PhysRevE.92.023020
Optimal control, Systems & Control, Foundations & Applications, p.507, 2000. ,
Necessary and Sufficient Conditions for Local Optimality of a Periodic Process, SIAM Journal on Control and Optimization, vol.28, issue.2, pp.28-482, 1990. ,
DOI : 10.1137/0328027
Typical singularities of differential 1-forms and Pfaffian equations, p.113, 1992. ,
