Strong minimality of abnormal geodesics for 2-distributions, Journal of Dynamical and Control Systems, vol.113, issue.2, pp.2-139, 1995. ,
DOI : 10.1007/978-94-010-2675-8_1
Optimal Strokes for Low Reynolds Number Swimmers: An Example, Journal of Nonlinear Science, vol.209, issue.3, pp.277-302, 2008. ,
DOI : 10.1007/978-3-642-61529-0
The tangent space in sub-Riemannian geometry, J. Math. Sci, vol.4, pp.83-461, 1997. ,
La taxonomie des courbes, Pour la science, vol.297, pp.56-63, 2002. ,
The three links Purcell swimmer and some geometric problems related to periodic optimal controls, Rad. Ser. Comp. App. Variational Methods, vol.18, 2016. ,
DOI : 10.1515/9783110430394-010
Sub-Riemannian geometry and swimming at low Reynolds number: the Copepod case. (preprint 2017 https ,
DOI : 10.1051/cocv/2017071
URL : https://hal.archives-ouvertes.fr/hal-01442880
Bocop -A collection of examples, Inria Research Report, p.8053, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00726992
Second order optimality conditions in the smooth case and applications in optimal control, ESAIM: Control, Optimisation and Calculus of Variations, vol.6, issue.2, pp.207-236, 2007. ,
DOI : 10.1051/cocv:2001115
URL : https://hal.archives-ouvertes.fr/hal-00086380
Singular trajectories and their role in control theory, Mathématiques & Applications, vol.40, 2003. ,
DOI : 10.1007/978-1-4471-5102-9_49-1
On the role of abnormal minimizers in sub-riemannian geometry, Annales de la facult?? des sciences de Toulouse Math??matiques, vol.10, issue.3, pp.10-405, 2001. ,
DOI : 10.5802/afst.998
URL : https://hal.archives-ouvertes.fr/hal-00086308
Les syst??mes de Pfaff, ?? cinq variables et les ??quations aux d??riv??es partielles du second ordre, Annales scientifiques de l'??cole normale sup??rieure, vol.27, pp.109-192, 1910. ,
DOI : 10.24033/asens.618
Small Subriemannian Balls on R 3, J. Dynam. Control Systems, vol.2, issue.3, pp.359-421, 1996. ,
Optimal strokes for driftless swimmers: A general geometric approach, ESAIM: Control, Optimisation and Calculus of Variations, 2014. ,
DOI : 10.1051/cocv/2017012
URL : https://hal.archives-ouvertes.fr/hal-00969259
Mechanics of swimming and flying, 1981. ,
DOI : 10.1017/CBO9780511569593
Contrôle optimal géométrique : méthodes homotopiques et applications, 2012. ,
Second Order Sufficient Conditions for Optimal Control Problems with Non-unique Minimizers: An Abstract Framework, Applied Mathematics & Optimization, vol.40, issue.3, pp.411-442, 2014. ,
DOI : 10.1137/S0363012999358725
URL : http://spiral.imperial.ac.uk/bitstream/10044/1/40471/2/final_2nd_order_Mar_02_2014.pdf
Non-minimality of corners in sub-Riemannian geometry, 2015. ,
The propulsion of sea-urchin spermatozoa, Journal of Experimental Biology, vol.32, pp.802-814, 1955. ,
Introduction to Hamiltonian dynamical systems and the N -body problem, 1992. ,
DOI : 10.1007/978-1-4757-4073-8
A tour of subriemannian geometries, their geodesics and applications, p.91, 2002. ,
DOI : 10.1090/surv/091
Supplementary notes to: Dynamics of Purcell's three-link microswimmer with a passive elastic tail, EPJ E, vol.35, pp.1-9, 2012. ,
Life at low Reynolds number, American Journal of Physics, vol.45, issue.1, pp.3-11, 1977. ,
DOI : 10.1119/1.10903
Méthodes géométriques et numériques en contrôle optimal et applications au transfert orbital poussée faible etàetà la nagè a faible nombre de Reynolds, 2016. ,
Symmetries of flat rank two distributions and sub-Riemannian structures, Trans. Amer. Math. Soc. n, vol.2, pp.356-457, 2004. ,
Swimming with stiff legs at low Reynolds number, Physical Review E, vol.138, issue.2, 2015. ,
DOI : 10.1137/S0036144504445133
Optimal control, Systems & Control, Foundations & Applications, p.507, 2000. ,
Necessary and sufficient conditions for local optimality of a periodic process, SIAM J. Control Optim. n, vol.2, pp.28-482, 1990. ,
Typical singularities of differential 1-forms and Pfaffian equations, p.113, 1992. ,
