Modelling and simulation of coastal lagoons Application to the Tunquen lagoon, Chilean pacific coast - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Modélisation et simulation des lagunes cotières, application à la lagune de Tunquen sur la côte pacifique chilienne.
Céline Acary-Robert
Loic Dagnas
  • Fonction : Auteur
  • PersonId : 1038857
The objective of this work is to provide a numerical model for the hydrodynamics of a lagoon located on the chilean coastline, characterized by an intermittent connection to the sea and a regular fresh water input coming from the Andes mountains. The model consists in a two-dimensional nonlinear shallow water system, including tracer equations for the time evolution of temperature and salinity. The water circulation in the lagoon accounts for external forcings such as water exchanges (with the atmosphere, rivers and sea), wind effects and external pumping. The paper includes a validation of the numerical method with respect to an analytical solution; numerical illustrations of involved geophysical processes and realistic simulation of typical scenarios of the Tunquén lagoon are provided. Software availability. The software sources will be made available for download on a free accessible repository .
article.pdf (2.15 Mo) Télécharger le fichier
hal-01921054 , version 1 (06-06-2016)
hal-01921054 , version 2 (13-11-2018)
  • HAL Id : hal-01921054 , version 2
Céline Acary-Robert, Loic Dagnas, Antoine Rousseau. Modelling and simulation of coastal lagoons Application to the Tunquen lagoon, Chilean pacific coast: Application to the Tunquén lagoon, Chilean pacific coast.. [Research Report] USMB; INRIA Sophia-Antipolis. 2016. ⟨hal-01921054v2⟩
539 Consultations
692 Téléchargements
