New interface
Conference papers
Packing graphs with ASP for landscape simulation
Thomas Guyet 1 Yves Moinard 1 Jacques Nicolas 2 René Quiniou 1
1 LACODAM - Large Scale Collaborative Data Mining
Inria Rennes – Bretagne Atlantique , IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
2 Dyliss - Dynamics, Logics and Inference for biological Systems and Sequences
Abstract : This paper describes an application of Answer Set Programming (ASP) to crop allocation for generating realistic landscapes. The aim is to cover optimally a bare landscape, represented by its plot graph, with spatial patterns describing local arrangements of crops. This problem belongs to the hard class of graph packing problems and is mod-eled in the framework of ASP. The approach provides a compact solution to the basic problem and at the same time allows extensions such as a flexible integration of expert knowledge. Particular attention is paid to the treatment of symmetries, especially due to sub-graph isomorphism issues. Experiments were conducted on a database of simulated and real landscapes. Currently, the approach can process graphs of medium size, a size that enables studies on real agricultural practices.
Document type :
Conference papers
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01327368
Contributor : Thomas Guyet Connect in order to contact the contributor
Submitted on : Monday, June 6, 2016 - 4:23:14 PM
Last modification on : Monday, October 31, 2022 - 6:58:10 PM
File
graph-packing.pdf
Identifiers
  • HAL Id : hal-01327368, version 1
Citation
Thomas Guyet, Yves Moinard, Jacques Nicolas, René Quiniou. Packing graphs with ASP for landscape simulation. IJCAI 2016 - 25th International joint conference on artificial intelligence , Jul 2016, New-york, United States. pp.8. ⟨hal-01327368⟩
Share
Metrics
Record views
443
Files downloads
215
