SOL: An End-to-end Solution for Real-World Remote Monitoring Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces SOL, which is both an efficient data representation for sensor measurements and network statistics, and a complete low-power wireless sensor management system that builds around it. A SOL system consists of multiple low-power wireless mesh networks in which motes connected to sensors and actuators send data to a single server. It offers multi-tier data replication and the associated data recovery. SOL is used in 3 pilot deployments for micro-climate monitoring, building automation and agriculture applications. In conjunction with Metronome Systems’ NeoMote and Manager devices, SOL is a turn-key ready-to-deploy end-to-end system.
brun16sol.pdf (400.89 Ko) Télécharger le fichier
hal-01327798 , version 1 (20-12-2016)
  • HAL Id : hal-01327798 , version 1
Keoma Brun-Laguna, Thomas Watteyne, Sami Malek, Ziran Zhang, Carlos Oroza, et al.. SOL: An End-to-end Solution for Real-World Remote Monitoring Systems. IEEE International Symposium on Personal, Indoor and Mobile Radio Communications (PIMRC), Sep 2016, Valencia, Spain. ⟨hal-01327798⟩
206 Consultations
187 Téléchargements
