Deriving Inverse Operators for Modal Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Spatial constraint systems are algebraic structures from concurrent constraint programming to specify spatial and epistemic behavior in multi-agent systems. We shall use spatial constraint systems to give an abstract characterization of the notion of normality in modal logic and to derive right inverse/reverse operators for modal languages. In particular, we shall identify the weakest condition for the existence of right inverses and show that the abstract notion of normality corresponds to the preservation of finite suprema. We shall apply our results to existing modal languages such as the weakest normal modal logic, Hennessy-Milner logic, and linear-time temporal logic. We shall discuss our results in the context of modal concepts such as bisimilarity and inconsistency invariance.
main.pdf (307.98 Ko) Télécharger le fichier
hal-01328188 , version 1 (07-06-2016)
hal-01328188 , version 2 (21-10-2016)
Copyright (Tous droits réservés)
Michell Guzman, Salim Perchy, Camilo Rueda, Frank Valencia. Deriving Inverse Operators for Modal Logic. Theoretical Aspects of Computing – ICTAC 2016, Oct 2016, Taipei, Taiwan. pp.214-232, ⟨10.1007/978-3-319-46750-4_13⟩. ⟨hal-01328188v2⟩
497 Consultations
377 Téléchargements
