P. Van-overschee and B. , De Moor, Subspace Identification for Linear Systems: Theory, 1996.
E. Reynders, System Identification Methods for (Operational) Modal Analysis: Review and Comparison, Archives of Computational Methods in Engineering, vol.15, issue.5, pp.51-124, 2012.
DOI : 10.1007/s11831-012-9069-x
M. Viberg, Subspace-based methods for the identification of linear time-invariant systems, Automatica, vol.31, issue.12, pp.1835-1851, 1995.
DOI : 10.1016/0005-1098(95)00107-5
N. Mastronardi, D. Kressner, V. Sima, P. V. Dooren, and S. V. Huffel, A fast algorithm for subspace state-space system identification via exploitation of the displacement structure, Journal of Computational and Applied Mathematics, vol.132, issue.1, pp.71-81, 2001.
DOI : 10.1016/S0377-0427(00)00600-2
E. Gandino and S. Marchesiello, Identification of a Duffing Oscillator under Different Types of Excitation, Mathematical Problems in Engineering, vol.3, issue.4, 2010.
DOI : 10.1016/j.ymssp.2007.09.004
M. Döhler and L. , Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012.
DOI : 10.1016/j.conengprac.2012.05.005
A. Benveniste and L. , Nonstationary Consistency of Subspace Methods, IEEE Transactions on Automatic Control, vol.52, issue.6, pp.974-984, 2007.
DOI : 10.1109/TAC.2007.898970
L. Ljung, System identification, 1999.
URL : https://hal.archives-ouvertes.fr/hal-00854858
M. Jansson and B. Wahlberg, A linear regression approach to state-space subspace system identification, Signal Processing, vol.52, issue.2, pp.103-129, 1996.
DOI : 10.1016/0165-1684(96)00048-5
C. T. Chou and M. Verhaegen, Subspace Algorithms for the Identification of Multivariable Dynamic Errors-in-Variables Models**This paper was not presented at any IFAC meeting. This paper was recommended for publication in revised form by Associate Editor H. Hjalmarsson under the direction of Editor Torsten S??derstr??m., Automatica, vol.33, issue.10, pp.1857-1869, 1997.
DOI : 10.1016/S0005-1098(97)00092-7
T. Gustafsson, Subspace identification using instrumental variable techniques, Automatica, vol.37, issue.12, 2001.
DOI : 10.1016/S0005-1098(01)00153-4
E. Gandino, L. Garibaldi, and S. Marchesiello, Covariance-driven subspace identification: A complete input???output approach, Journal of Sound and Vibration, vol.332, issue.26, pp.7000-7017, 2013.
DOI : 10.1016/j.jsv.2013.08.025
B. Peeters and G. De-roeck, REFERENCE-BASED STOCHASTIC SUBSPACE IDENTIFICATION FOR OUTPUT-ONLY MODAL ANALYSIS, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.855-878, 1999.
DOI : 10.1006/mssp.1999.1249
M. Basseville, L. Mevel, and M. Goursat, Statistical model-based damage detection and localization: subspace-based residuals and damage-to-noise sensitivity ratios, Journal of Sound and Vibration, vol.275, issue.3-5, pp.769-794, 2004.
DOI : 10.1016/j.jsv.2003.07.016
URL : https://hal.archives-ouvertes.fr/inria-00071940
M. Döhler and L. , Subspace-based fault detection robust to changes in the noise covariances, Automatica, vol.49, issue.9, pp.2734-2743, 2013.
DOI : 10.1016/j.automatica.2013.06.019
L. Mevel, M. Basseville, A. Benveniste, and M. Goursat, MERGING SENSOR DATA FROM MULTIPLE MEASUREMENT SET-UPS FOR NON-STATIONARY SUBSPACE-BASED MODAL ANALYSIS, Journal of Sound and Vibration, vol.249, issue.4, pp.719-741, 2002.
DOI : 10.1006/jsvi.2001.3880
A. Guyader and L. , Covariance-driven subspace methods: input/output vs. output-only, Proceedings of the 21st International Modal Analysis Conference, 2003.
L. Mevel, A. Benveniste, M. Basseville, M. Goursat, B. Peeters et al., Input/output versus output-only data processing for structural identification???Application to in-flight data analysis, Journal of Sound and Vibration, vol.295, issue.3-5, pp.531-552, 2006.
DOI : 10.1016/j.jsv.2006.01.039
M. Döhler and L. , Modular Subspace-Based System Identification From Multi-Setup Measurements, IEEE Transactions on Automatic Control, vol.57, issue.11, pp.2951-2956, 2012.
DOI : 10.1109/TAC.2012.2193711
M. Viberg, B. Wahlberg, and B. Ottersten, Analysis of state space system identification methods based on instrumental variables and subspace fitting, Automatica, vol.33, issue.9, pp.1603-1616, 1997.
DOI : 10.1016/S0005-1098(97)00097-6
D. Bauer, M. Deistler, and W. Scherrer, Consistency and asymptotic normality of some subspace algorithms for systems without observed inputs, Automatica, vol.35, issue.7, pp.1243-1254, 1999.
DOI : 10.1016/S0005-1098(99)00031-X
A. Chiuso and G. Picci, The asymptotic variance of subspace estimates, Journal of Econometrics, vol.118, issue.1-2, pp.257-291, 2004.
DOI : 10.1016/S0304-4076(03)00143-X
D. Bauer, Asymptotic properties of subspace estimators, Automatica, vol.41, issue.3, pp.359-376, 2005.
DOI : 10.1016/j.automatica.2004.11.012
M. Raffy and C. Gontier, Statistical asymptotic error on modal parameters in combined deterministic???stochastic identification algorithm, Mechanical Systems and Signal Processing, vol.19, issue.4, pp.714-735, 2005.
DOI : 10.1016/j.ymssp.2004.11.001
R. Pintelon, P. Guillaume, and J. Schoukens, Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, vol.21, issue.6, pp.2359-2373, 2007.
DOI : 10.1016/j.ymssp.2006.11.007
E. Reynders, R. Pintelon, and G. De-roeck, Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008.
DOI : 10.1016/j.ymssp.2007.10.009
M. Döhler and L. , Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, issue.2, pp.346-366, 2013.
DOI : 10.1016/j.ymssp.2013.01.012
M. Döhler, X. Lam, and L. , Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, issue.2, pp.562-581, 2013.
DOI : 10.1016/j.ymssp.2012.11.011
M. Döhler, F. Hille, L. Mevel, and W. Rücker, Structural health monitoring with statistical methods during progressive damage test of S101 Bridge, Engineering Structures, vol.69, pp.183-193, 2014.
DOI : 10.1016/j.engstruct.2014.03.010
E. Reynders and G. D. Roeck, Reference-based combined deterministic???stochastic subspace identification for experimental and operational modal analysis, Mechanical Systems and Signal Processing, vol.22, issue.3, pp.617-637, 2008.
A. Esna-ashari and L. , Input-Output Subspace-Based Fault Detection*, Proc. 8th IFAC Symposium on fault detection, diagnosis and safety of technical processes (SAFEPROCESS), pp.204-209, 2012.
DOI : 10.3182/20120829-3-MX-2028.00113
URL : https://hal.archives-ouvertes.fr/hal-00695619
M. Verhaegen, Application of a subspace model identification technique to identify LTI systems operating in closed-loop, Automatica, vol.29, issue.4, pp.1027-1040, 1993.
DOI : 10.1016/0005-1098(93)90104-2
P. Van-overschee, B. De, and . Moor, N4SID: Subspace algorithms for the identification of combined deterministic-stochastic systems, Automatica, vol.30, issue.1, pp.75-93, 1994.
DOI : 10.1016/0005-1098(94)90230-5
M. Verhaegen, Identification of the deterministic part of MIMO state space models given in innovations form from input-output data, Automatica, vol.30, issue.1, pp.61-74, 1994.
DOI : 10.1016/0005-1098(94)90229-1
E. Hannan, Multiple time series, 1970.
A. Benveniste and J. Fuchs, Single sample modal identification of a nonstationary stochastic process, IEEE Transactions on Automatic Control, vol.30, issue.1, pp.66-74, 1985.
DOI : 10.1109/TAC.1985.1103787
G. Casella and R. Berger, Statistical Inference., Biometrics, vol.49, issue.1, 2002.
DOI : 10.2307/2532634
J. Brewer, Kronecker products and matrix calculus in system theory, IEEE Transactions on Circuits and Systems, vol.25, issue.9, pp.772-781, 1978.
DOI : 10.1109/TCS.1978.1084534
M. Döhler, X. Lam, and L. , Multi-Order Covariance Computation for Estimates in Stochastic Subspace Identification Using QR Decompositions, Proc. 19th IFAC World Congress, 2014.
DOI : 10.3182/20140824-6-ZA-1003.00883
W. Gersch, On the achievable accuracy of structural system parameter estimates, Journal of Sound and Vibration, vol.34, issue.1, pp.63-79, 1974.
DOI : 10.1016/S0022-460X(74)80355-X
C. R. Pickrel and P. J. White, Flight flutter testing of transport aircraft: in-flight modal analysis, Proc. 21st International Modal Analysis Conference, 2003.
P. Van-overschee and B. , A unifying theorem for three subspace system identification algorithms, Automatica, vol.31, issue.12, pp.1853-1864, 1995.
DOI : 10.1016/0005-1098(95)00072-0
