Abstract : Heap monoids equipped with Bernoulli measures are a model of probabilistic asynchronous systems. We introduce in this framework the notion of asynchronous stopping time, which is analogous to the notion of stopping time for classical probabilistic processes. A Strong Bernoulli property is proved. A notion of cut-invariance is formulated for convergent ergodic means. Then a version of the Strong law of large numbers is proved for heap monoids with Bernoulli measures. Finally, we study a sub-additive version of the Law of large numbers in this framework based on Kingman sub-additive Ergodic Theorem.
