Comprehensive in vitro Proarrhythmia Assay (CiPA): Pending issues for successful validation and implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Pharmacological and Toxicological Methods Année : 2016
Introduction: The Comprehensive in vitro Proarrhythmia Assay (CiPA) is a nonclinical Safety Pharmacology paradigm for discovering electrophysiological mechanisms that are likely to confer proarrhythmic liability to drug candidates intended for human use. Topics covered: Key talks delivered at the ‘CiPA on my mind’ session, held during the 2015 Annual Meeting of the Safety Pharmacology Society (SPS), are summarized. Issues and potential solutions relating to crucial constituents [e.g., biological materials (ion channels and pluripotent stem cell-derived cardiomyocytes), study platforms, drug solutions, and data analysis] of CiPA core assays are critically examined. Discussion: In order to advance the CiPA paradigm from the current testing and validation stages to a research and regulatory drug development strategy, systematic guidance by CiPA stakeholders is necessary to expedite solutions to pending and newly arising issues. Once a study protocol is proved to yield robust and reproducible results within and across laboratories, it can be implemented as qualified regulatory procedure.
cipa-cavero-2016.pdf (1020.54 Ko) Télécharger le fichier
hal-01328481 , version 1 (08-06-2016)
Icilio Cavero, Jean-Michel Guillon, Veronique Ballet, Mike Clements, Jean-Frédéric Gerbeau, et al.. Comprehensive in vitro Proarrhythmia Assay (CiPA): Pending issues for successful validation and implementation. Journal of Pharmacological and Toxicological Methods, 2016, 81, pp.21-36. ⟨10.1016/j.vascn.2016.05.012⟩. ⟨hal-01328481⟩
578 Consultations
1737 Téléchargements
