Understanding Connectivity between Groundwater Chemistry Data and Geological Stratigraphy via 3D Sub-surface Visualization and Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jane Hunter
  • Fonction : Auteur
  • PersonId : 983311
Andre Gebers
  • Fonction : Auteur
  • PersonId : 983312
Lucy Reading
  • Fonction : Auteur
  • PersonId : 983313
Sue Vink
  • Fonction : Auteur
  • PersonId : 983314
This paper describes the 3D Water Chemistry Atlas - an open source, Web-based system that enables the three-dimensional (3D) sub-surface visualization of ground water monitoring data, overlaid on the local geological model. Following a review of existing technologies, the system adopts Cesium (an open source Web-based 3D mapping and visualization interface) together with a PostGreSQL/PostGIS database, for the technical architecture. In addition a range of the search, filtering, browse and analysis tools were developed that enable users to interactively explore the groundwater monitoring data and interpret it spatially and temporally relative to the local geological formations and aquifers via the Cesium interface. The result is an integrated 3D visualization system that enables environmental managers and regulators to assess groundwater conditions, identify inconsistencies in the data, manage impacts and risks and make more informed decisions about activities such as coal seam gas extraction, waste water extraction and re-use.
978-3-319-15994-2_48_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01328595 , version 1 (08-06-2016)
Paternité
Jane Hunter, Andre Gebers, Lucy Reading, Sue Vink. Understanding Connectivity between Groundwater Chemistry Data and Geological Stratigraphy via 3D Sub-surface Visualization and Analysis. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. pp.475-483, ⟨10.1007/978-3-319-15994-2_48⟩. ⟨hal-01328595⟩
53 Consultations
644 Téléchargements
