Conference papers
A New Approach for Coupled Regional Climate Modeling Using More than 10,000 Cores
Abstract : This paper describes an alternative method for coupling atmosphere-ocean regional climate models that communicates momentum, radiation, heat and moisture fluxes between the atmosphere and ocean every time-step, while scaling to more than 10,000 cores. The approach is based on the reversibly staggered grid, which possesses excellent dispersive properties for modeling the geophysical fluid dynamics of both the atmosphere and the ocean. Since a common reversibly staggered grid can be used for both atmosphere and ocean models, we can eliminate the coupling overhead associated with message passing and improve simulation timings. We have constructed a prototype of a reversibly staggered, atmosphere-ocean coupled regional climate model based on the Conformal Cubic Atmospheric Model, which employs a global variable resolution cube-based grid to model the regional climate without lateral boundary conditions. With some optimization, the single precision, semi-implicit, semi-Lagrangian prototype model achieved 5 simulation years per day at a global 13 km resolution using 13,824 cores. This result is competitive with state-of-the-art Global Climate Models than can use more than 100,000 cores for comparable timings, making CCAM well suited for regional modeling.
Document type :
Conference papers
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01328612
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, June 8, 2016 - 11:23:33 AM
Last modification on : Sunday, February 24, 2019 - 6:22:02 PM
File
978-3-319-15994-2_61_Chapter.p...
Identifiers
Citation
Marcus Thatcher, John Mcgregor, Martin Dix, Jack Katzfey. A New Approach for Coupled Regional Climate Modeling Using More than 10,000 Cores. 11th International Symposium on Environmental Software Systems (ISESS), Mar 2015, Melbourne, Australia. pp.599-607, ⟨10.1007/978-3-319-15994-2_61⟩. ⟨hal-01328612⟩
Share
Metrics
Record views
76
Files downloads
207
