The Fast Construction of Extension Velocities in Level Set Methods, Journal of Computational Physics, vol.148, issue.1, pp.2-22, 1999. ,
DOI : 10.1006/jcph.1998.6090
A continuum method for modeling surface tension, Journal of Computational Physics, vol.100, issue.2, pp.335-354, 1992. ,
DOI : 10.1016/0021-9991(92)90240-Y
A monotonicity preserving conservative sharp interface flow solver for high density ratio two-phase flows, J. Comput. Phys, vol.249, pp.185-203, 2013. ,
Numerical solution of the Navier-Stokes equations, Mathematics of Computation, vol.22, issue.104, pp.745-762, 1968. ,
DOI : 10.1090/S0025-5718-1968-0242392-2
Abstract, Communications in Computational Physics, vol.39, issue.05, pp.1562-1587, 2012. ,
DOI : 10.1016/j.jcp.2006.02.014
Développement d'un code de calcul pour la simulation d'écoulements de fluides non miscibles: application à la désintégration assistée d'un jet liquide par un courant gazeux, ENSAE, 2007. ,
A spectrally refined interface approach for simulating multiphase flows, Journal of Computational Physics, vol.228, issue.5, pp.1658-1677, 2009. ,
DOI : 10.1016/j.jcp.2008.11.005
Second-Order Accurate Computation of Curvatures in a Level Set Framework Using Novel High-Order Reinitialization Schemes, Journal of Scientific Computing, vol.114, issue.2-3, pp.114-131, 2008. ,
DOI : 10.1007/s10915-007-9177-1
On stability condition for bifluid flows with surface tension: Application to microfluidics, Journal of Computational Physics, vol.227, issue.12, pp.6140-61648380, 2008. ,
DOI : 10.1016/j.jcp.2008.02.023
URL : https://hal.archives-ouvertes.fr/hal-00274569
The influence of density ratio on the primary atomization of a turbulent liquid jet in crossflow, Proceedings of the Combustion Institute, vol.33, issue.2, pp.2079-2088, 2011. ,
DOI : 10.1016/j.proci.2010.07.002
A conservative interface method for compressible flows, Journal of Computational Physics, vol.219, issue.2, pp.553-578, 2006. ,
DOI : 10.1016/j.jcp.2006.04.001
URL : http://mediatum.ub.tum.de/doc/1343198/document.pdf
A boundary condition capturing method for multiphase incompressible flow, Journal of Scientific Computing, vol.15, issue.3, pp.323-360, 2000. ,
DOI : 10.1023/A:1011178417620
A Boundary Condition Capturing Method for Poisson's Equation on Irregular Domains, Journal of Computational Physics, vol.160, issue.1, pp.151-178, 2000. ,
DOI : 10.1006/jcph.2000.6444
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.45.5776
Enablers for high-order level set methods in fluid mechanics, International Journal for Numerical Methods in Fluids, vol.155, issue.2, pp.654-675, 2015. ,
DOI : 10.1002/fld.4070
URL : https://hal.archives-ouvertes.fr/hal-01250641
Abstract, Communications in Computational Physics, vol.230, issue.05, pp.1266-1290, 2014. ,
DOI : 10.1002/fld.1281
A level-set approach for computing solutions to incompressible two-phase flows, J. Comput. Phys, vol.114, pp.146-159, 1994. ,
Part IV. An Experimental Study of the Collapse of Liquid Columns on a Rigid Horizontal Plane, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.244, issue.882, pp.312-324, 1952. ,
DOI : 10.1098/rsta.1952.0006
URL : https://hal.archives-ouvertes.fr/hal-00518739
A versatile sharp interface immersed boundary method for incompressible flows with complex boundaries, Journal of Computational Physics, vol.227, issue.10, pp.4825-4852, 2008. ,
DOI : 10.1016/j.jcp.2008.01.028
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2834215
Level Set Methods and Dynamic Implicit Surfaces, 2003. ,
DOI : 10.1115/1.1760520
URL : http://dx.doi.org/10.1016/s0898-1221(03)90179-9
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, p.79, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.413.5254
Consistent mass and momentum transport for simulating incompressible interfacial flows with large density ratios using the level set method, Computers & Fluids, vol.63, pp.70-81, 2012. ,
DOI : 10.1016/j.compfluid.2012.04.002
Numerical study of the turbulent flow past an airfoil with trailing edge separation, AIAA Journal, vol.21, issue.11, pp.1525-1532, 1983. ,
DOI : 10.2514/3.8284
A Viscosity Solutions Approach to Shape-From-Shading, SIAM Journal on Numerical Analysis, vol.29, issue.3, pp.867-884, 1992. ,
DOI : 10.1137/0729053
A volume-tracking method for incompressible multifluid flows with large density variations, International Journal for Numerical Methods in Fluids, vol.229, issue.2, pp.357-378, 1998. ,
DOI : 10.1002/(SICI)1097-0363(19980815)28:2<357::AID-FLD750>3.0.CO;2-D
A Remark on Computing Distance Functions, Journal of Computational Physics, vol.163, issue.1, pp.51-67, 2000. ,
DOI : 10.1006/jcph.2000.6553
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.398.6810
Level Set Methods and Fast Marching Methods, 1999. ,
Evolution, Implementation, and Application of Level Set and Fast Marching Methods for Advancing Fronts, Journal of Computational Physics, vol.169, issue.2, pp.503-555, 2001. ,
DOI : 10.1006/jcph.2000.6657
A fast marching level set method for monotonically advancing fronts., Proceedings of the National Academy of Sciences, vol.93, issue.4, pp.1591-1595, 1996. ,
DOI : 10.1073/pnas.93.4.1591
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC39986
Efficient Implementation of Weighted ENO Schemes, Journal of Computational Physics, vol.126, issue.1, pp.202-228, 1995. ,
DOI : 10.1006/jcph.1996.0130
A Coupled Level Set and Volume-of-Fluid Method for Computing 3D and Axisymmetric Incompressible Two-Phase Flows, Journal of Computational Physics, vol.162, issue.2, pp.301-337, 2000. ,
DOI : 10.1006/jcph.2000.6537
A sharp interface method for incompressible two-phase flows, Journal of Computational Physics, vol.221, issue.2, pp.469-505, 2007. ,
DOI : 10.1016/j.jcp.2006.06.020
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.413.7193
A Level Set Method for vaporizing two-phase flows, Journal of Computational Physics, vol.221, issue.2, pp.837-853, 2007. ,
DOI : 10.1016/j.jcp.2006.07.003
URL : https://hal.archives-ouvertes.fr/hal-00649783
Sur l'approximation de la solution des equations de navier-stokes par la méthode des pas fractionnaires ii, Archiv. Rat. Mech. Anal, vol.32, pp.377-385, 1969. ,
Fast sweeping algorithms for a class of hamiltonjacobi equations, SIAM J. Numer. Anal, vol.41, pp.673-694, 2003. ,
