Unilateral Contact, CISM Courses and Lectures no 384, pp.1-54, 1999. ,
DOI : 10.1007/978-3-7091-2496-3_1
Dissipative Systems and Stability ,
Response probability density functions of Duffing???Van der Pol vibro-impact system under correlated Gaussian white noise excitations, Physica A: Statistical Mechanics and its Applications, vol.392, issue.6, pp.1269-1279, 2013. ,
DOI : 10.1016/j.physa.2012.11.053
Subharmonic response of a single-degree-of-freedom nonlinear vibroimpact system to a randomly disordered periodic excitation, Journal of Sound and Vibration, vol.327, issue.1-2, pp.173-182, 2009. ,
DOI : 10.1016/j.jsv.2009.06.006
Stochastic responses of Duffing-Van der Pol vibro-impact system under additive and multiplicative random excitations, International Journal of Non-Linear Mechanics, vol.44, issue.1, pp.51-57, 2009. ,
DOI : 10.1016/j.ijnonlinmec.2008.08.013
Stochastic responses of vibro-impact duffing oscillator excited by additive Gaussian noise, Journal of Sound and Vibration, vol.309, issue.3-5, pp.730-738, 2009. ,
DOI : 10.1016/j.jsv.2007.07.070
On the determination of the damping coefficient of nonlinear spring-dashpot system to model Hertz contact for simulation by discrete element method, 2010 WASE International Conference on, pp.295-298, 2010. ,
Comparative evaluation of normal viscoelastic contact force models in low velocity impact situations, Advanced Powder Technology, 2016. ,
Shock dynamics in granular chains: numerical simulations and comparison with experimental tests, Granular Matter, vol.465, issue.2107, pp.341-362, 2012. ,
DOI : 10.1098/rspa.2008.0520
URL : https://hal.archives-ouvertes.fr/inria-00597468
Multiple Impacts in Dissipative Granular Chains, Lecture Notes in Applied and Computational Mechanics, vol.72, 2014. ,
DOI : 10.1007/978-3-642-39298-6
URL : https://hal.archives-ouvertes.fr/hal-00908612
The Painlev?? paradox in contact mechanics, IMA Journal of Applied Mathematics, vol.470, issue.3, pp.538-588, 2016. ,
DOI : 10.1115/1.4028844
A complementarity approach for the computation of periodic oscillations in piecewise linear systems, Nonlinear Dynamics, vol.269, issue.5 ,
DOI : 10.1016/j.physd.2013.11.013
Nonsmooth Lagrangian Mechanics and Variational Collision Integrators, SIAM Journal on Applied Dynamical Systems, vol.2, issue.3, pp.381-416, 2003. ,
DOI : 10.1137/S1111111102406038
URL : https://epubs.siam.org/doi/pdf/10.1137/S1111111102406038
On the number of solutions to a class of linear complementarity problems, Mathematical Programming, pp.136-139, 1979. ,
DOI : 10.1007/BF01588239
Vibro-Impact Problems with Dry Friction---Part I: Existence Result, SIAM Journal on Mathematical Analysis, vol.47, issue.5, pp.3285-3313, 2015. ,
DOI : 10.1137/140988899
URL : https://hal.archives-ouvertes.fr/hal-02074443
Vibro-Impact Problems with Dry Friction---Part II: Tangential Contacts and Frictional Catastrophes, SIAM Journal on Mathematical Analysis, vol.48, issue.2, pp.1272-1296, 2016. ,
DOI : 10.1137/140988905
URL : https://hal.archives-ouvertes.fr/hal-02074455
New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, 1998. ,
DOI : 10.1016/S0997-7538(99)00144-8
Preservation of Prox-Regularity of Sets with Applications to Constrained Optimization, SIAM Journal on Optimization, vol.26, issue.1, pp.448-473, 2016. ,
DOI : 10.1137/15M1032739
URL : https://hal.archives-ouvertes.fr/hal-01313215
Stability and observer design for Lur'e systems with multivalued , non-monotone, time-varying nonlinearities and state jumps, SIAM J. Control and Optimization, vol.56, issue.2, pp.3639-3672, 2014. ,
Stability analysis and attractivity results of a DC-DC Buck converter, Set-Valued Var, Anal, vol.20, pp.331-353, 2012. ,
Variational analysis and generalized equations in electronics, Set-Valued Var, Anal, vol.21, pp.333-358, 2013. ,
DOI : 10.1007/s11228-013-0236-5
Finite time stabilisation of nonlinear oscillators subject to dry friction, in Nonsmooth Mechanics and Analysis, pp.289-304, 2006. ,
DOI : 10.1007/0-387-29195-4_24
An inertial proximal algorithm with dry friction: finite convergence results, Set-Valued Analysis, pp.1-23, 2006. ,
DOI : 10.1007/s11228-005-0002-4
Seismic vulnerability of ancient stone arches by using a numerical model based on the Non-Smooth Contact Dynamics method, Engineering Structures, vol.119, pp.110-121, 2016. ,
DOI : 10.1016/j.engstruct.2016.04.001
On the contact stiffness and nonlinear vibration of an elastic body with a rough surface in contact with a rigid flat surface, European Journal of Mechanics - A/Solids, vol.49, pp.321-328, 2015. ,
DOI : 10.1016/j.euromechsol.2014.08.005
Docking dynamics between two spacecrafts with APDSes, Multibody System Dynamics, vol.469, issue.2107, 2016. ,
DOI : 10.1098/rspa.2012.0741
The unexpectedly small coefficient of restitution of a two-degree-of-freedom mass-spring system and its implications, International Journal of Impact Engineering, vol.88, pp.1-11, 2016. ,
DOI : 10.1016/j.ijimpeng.2015.09.005
Coefficient of restitution for one-dimensional harmonic solids, Physical Review E, vol.64, issue.2, pp.2015-2023, 2000. ,
DOI : 10.1115/1.2787319
Collision of one-dimensional nonlinear chains, Physical Review E, vol.61, issue.3, p.36609, 2003. ,
DOI : 10.1103/PhysRevE.61.2015
URL : http://arxiv.org/pdf/cond-mat/0210374
Recurrence, controllability, and stabilization of juggling, IEEE Transactions on Robotics and Automation, vol.17, issue.2, pp.113-124, 2001. ,
DOI : 10.1109/70.928557
URL : http://lims.mech.nwu.edu/~lynch/papers/ieeetra2001/ieeetra2001.pdf
Modelling contact in rocking structures with a nonsmooth dynamics approach, ECCOMAS Congress, Crete Island, Greece, pp.5-10, 2016. ,
DOI : 10.7712/100016.2162.8384
URL : https://files.eccomasproceedia.org/papers/eccomas-congress-2016/8384.pdf?mtime=20170308164124
Force Measurement Time-Delays and Contact Instability Phenomenon, European Journal of Control, vol.5, issue.2-4, pp.279-289, 1999. ,
DOI : 10.1016/S0947-3580(99)70163-9
Discussion on:???Force Measurement Time-Delays and Contact Instability Phenomenon??? by S.-I. Niculescu and B. Brogliato, European Journal of Control, vol.5, issue.2-4, pp.290-292, 1999. ,
DOI : 10.1016/S0947-3580(99)70164-0
Model of the UIC link suspension for freight wagons, Archive of Applied Mechanics (Ingenieur Archiv), vol.73, issue.7, pp.517-532, 2003. ,
DOI : 10.1007/s00419-003-0305-6
On the numerical and computational aspects of non-smoothnesses that occur in railway vehicle dynamics, Mathematics and Computers in Simulation, vol.95, pp.78-97, 2013. ,
DOI : 10.1016/j.matcom.2012.09.016
A Variational Approach to Copositive Matrices, SIAM Review, vol.52, issue.4, pp.593-629, 2010. ,
DOI : 10.1137/090750391
