Unilateral Contact: Mechanical Modelling, New Developments in Contact Problems, vol.384, pp.1-54, 1999. ,
, Dissipative Systems and Stability
Response probability density functions of Duffing-Van der Pol vibro-impact system under correlated Gaussian white noise excitation, Physica A, vol.392, pp.1269-1279, 2013. ,
Subharmonic response of a single-degree-of-freedom nonlinear vibroimpact system to a ramdomly disordered periodic excitation, Journal of Sound and Vibration, vol.327, pp.173-182, 2009. ,
Stochastic responses of Duffing-Van der Pol vibro-impact system under additive and multiplicative random excitations, Int. J. of Non-Linear Mechanics, vol.44, pp.51-57, 2009. ,
Stochastic responses of vibro-impact Duffing oscillator excited by additive Gaussian noise, Journal of Sound and Vibration, vol.309, pp.730-738, 2009. ,
On the determination of the damping coefficient of nonlinear spring-dashpot system to model Hertz contact for simulation by discrete element method, Information Engineering (ICIE), WASE International Conference on, vol.3, pp.14-15, 2010. ,
Comparative evaluation of normal viscoelastic contact force models in low velocity impact situations, Advanced Powder Technology, 2016. ,
Shock dynamics in granular chains: numerical simulations and comparisons with experimental tests, Granular Matter, vol.14, pp.341-362, 2012. ,
Multiple Impacts in Dissipative Granular Chains, Lecture Notes in Applied and Computational Mechanics, vol.72, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00908612
The Painlevé paradox in contact mechanics, IMA Journal of Applied Mathematics, vol.81, pp.538-588, 2016. ,
A complementarity approach for the computation of periodic oscillations in piecewise linear systems, Nonlinear Dynamics ,
Nonsmooth Lagrangian mechanics and variational collision integrators, SIAM J. Applied Dynamical Systems, vol.2, pp.381-416, 2003. ,
On the number of solutions to a class of linear complementarity problems, Mathematical Programming, vol.17, pp.136-139, 1979. ,
Vibro-impact problems with dry friction-Part I: Existence result, SIAM J. Math. Anal, vol.47, issue.5, pp.3285-3313, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-02074443
Vibro-impact problems with dry friction-Part II: Tangential contacts and frictional catastrophes, SIAM J. Math. Anal, vol.48, issue.2, pp.1272-1296, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-02074455
New results on Painlevé paradoxes, INRIA Research Report, vol.3366, 1998. ,
Preservation of prox-regularity of sets with applications to constrained optimization, SIAM J. Optim, vol.26, issue.1, pp.448-473, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01313215
Stability and observer design for Lur'e systems with multivalued, non-monotone, time-varying nonlinearities and state jumps, SIAM J. Control and Optimization, vol.56, issue.2, pp.3639-3672, 2014. ,
Stability analysis and attractivity results of a DC-DC Buck converter, Set-Valued Var, Anal, vol.20, pp.331-353, 2012. ,
Variational analysis and generalized equations in electronics, Set-Valued Var, Anal, vol.21, pp.333-358, 2013. ,
Finite time stabilisation of nonlinear oscillators subject to dry friction, Nonsmooth Mechanics and Analysis, vol.24, pp.289-304, 2006. ,
An inertial proximal algorithm with dry friction: finite convergence results, Set-Valued Analysis, vol.9, pp.1-23, 2006. ,
Seismic vulnerability of ancient stone arches by using a numerical model based on the Non-Smooth Contact Dynamics method, Engineering Structures, vol.119, pp.110-121, 2016. ,
On the contact stiffness and nonlinear vibration of an elastic body with a rough surface in contact with a rigid flat surface, European Journal of Mechanics A/Solids, vol.49, pp.321-328, 2015. ,
Docking dynamics between two spacecrafts with APDSes, Multibody System Dynamics, 2016. ,
The unexpectedly small coefficient of restitution of a two-degree-of-freedom mass-spring system and its implications, International Journal of Impact Engineering, vol.88, pp.1-11, 2016. ,
Coefficient of restitution for one-dimensional harmonic solids, Phys. Rev. E, vol.61, issue.2, 2000. ,
Collision of one-dimensional nonlinear chains, Physical Review A, vol.67, p.36609, 2003. ,
Recurrence, controllability, and stabilization of juggling, IEEE Transactions on Robotics and Automation, vol.17, pp.113-124, 2001. ,
Modelling contact in rocking structures with a nonsmooth dynamics approach, VVII European Congress on Computational Methods in Applied Sciences and Engineering, M. Papadrakakis, pp.5-10, 2016. ,
Force measurement time-delays and contact instability phenomenon, European Journal of Control, vol.5, pp.279-289, 1999. ,
Force measurement time-delays and contact instability phenomenon, European Journal of Control, vol.5, pp.290-292, 1999. ,
Model of the UIC link suspension for freight wagons, Archive of Applied Mechanics, vol.73, pp.517-532, 2003. ,
On the numerical and computational aspects of nonsmoothness that occur inrailway vehicla dynamics, Mathematics and Computers in Simulation, vol.95, pp.78-97, 2013. ,
A variational approach to copositive matrices, vol.52, pp.593-629, 2010. ,
Scalar generalization of Newtonian restitution for simultaneous impact, International Journal of Mechanical sciences, vol.103, pp.141-157, 2015. ,
