Real-time sound synthesis for paper material based on geometric analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, we present the first method to generate plausible sounds while animating crumpling virtual paper in real time. Our method handles shape-dependent friction and crumpling sounds which typically occur when manipulating or creasing paper by hand. Based on a run-time geometric analysis of the deforming surface, we identify resonating regions characterizing the sound being produced. Coupled to a fast analysis of the surrounding elements, the sound can be efficiently spatialized to take into account nearby wall or table reflectors. Finally, the sound is synthesized in real time using a pre-recorded database of frequency- and time-domain sound sources. Our synthesized sounds are evaluated by comparing them to recordings for a specific set of paper deformations.
sca_camera_ready_paper_sound.pdf (18.81 Mo) Télécharger le fichier
sound_of_paper.flv (44.35 Mo) Télécharger le fichier
sound_of_paper.mp4 (41.46 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Vidéo
hal-01333238 , version 1 (17-06-2016)
hal-01333238 , version 2 (24-06-2016)
hal-01333238 , version 3 (28-06-2016)
  • HAL Id : hal-01333238 , version 1
Camille Schreck, Damien Rohmer, Doug James, Stefanie Hahmann, Marie-Paule Cani. Real-time sound synthesis for paper material based on geometric analysis. Eurographics/ ACM SIGGRAPH Symposium on Computer Animation (2016), Jul 2016, Zürich, Switzerland. ⟨hal-01333238v1⟩
1008 Consultations
360 Téléchargements
