New interface
Conference papers
Extracting the Core Structural Connectivity Network: Guaranteeing Network Connectedness Through a Graph-Theoretical Approach
Demian Wassermann 1 Dorian Mazauric 2 Guillermo Gallardo-Diez 1 Rachid Deriche 1
1 ATHENA - Computational Imaging of the Central Nervous System
CRISAM - Inria Sophia Antipolis - Méditerranée
2 ABS - Algorithms, Biology, Structure
Abstract : We present a graph-theoretical algorithm to extract the connected core structural connectivity network of a subject population. Extracting this core common network across subjects is a main problem in current neuroscience. Such network facilitates cognitive and clinical analyses by reducing the number of connections that need to be explored. Furthermore, insights into the human brain structure can be gained by comparing core networks of different populations. We show that our novel algorithm has theoretical and practical advantages. First, contrary to the current approach our algorithm guarantees that the extracted core subnetwork is connected agreeing with current evidence that the core structural network is tightly connected. Second, our algorithm shows enhanced performance when used as feature selection approach for connectivity analysis on populations.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01333301
Contributor : Demian Wassermann Connect in order to contact the contributor
Submitted on : Tuesday, July 12, 2016 - 3:59:04 PM
Last modification on : Saturday, June 25, 2022 - 11:20:53 PM
main.pdf
Identifiers
  • HAL Id : hal-01333301, version 2
Collections
Citation
Demian Wassermann, Dorian Mazauric, Guillermo Gallardo-Diez, Rachid Deriche. Extracting the Core Structural Connectivity Network: Guaranteeing Network Connectedness Through a Graph-Theoretical Approach. MICCAI 2016, Sep 2016, Athens, Greece. ⟨hal-01333301v2⟩
Share
Metrics
Record views
209
Files downloads
393
