Multichannel Music Separation with Deep Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article addresses the problem of multichannel music separation. We propose a framework where the source spectra are estimated using deep neural networks and combined with spatial covariance matrices to encode the source spatial characteristics. The parameters are estimated in an iterative expectation-maximization fashion and used to derive a multichannel Wiener filter. We evaluate the proposed framework for the task of music separation on a large dataset. Experimental results show that the method we describe performs consistently well in separating singing voice and other instruments from realistic musical mixtures.
eusipco_w_ack.pdf (385.77 Ko) Télécharger le fichier
hal-01334614 , version 1 (21-06-2016)
hal-01334614 , version 2 (14-06-2017)
  • HAL Id : hal-01334614 , version 2
Aditya Arie Nugraha, Antoine Liutkus, Emmanuel Vincent. Multichannel Music Separation with Deep Neural Networks. European Signal Processing Conference (EUSIPCO), Aug 2016, Budapest, Hungary. pp.1748-1752. ⟨hal-01334614v2⟩
516 Consultations
1110 Téléchargements
