Model Finding for Recursive Functions in SMT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
SMT solvers have recently been extended with techniques for finding models of universally quantified formulas in some restricted fragments of first-order logic. This paper introduces a translation that reduces axioms specifying a large class of recursive functions, including terminating functions, to universally quantified formulas for which these techniques are applicable. An evaluation confirms that the approach improves the performance of existing solvers on benchmarks from three sources. The translation is implemented as a preprocessor in the CVC4 solver and in a new higher-order model finder called Nunchaku.
conf.pdf (192.84 Ko) Télécharger le fichier
hal-01336082 , version 1 (22-06-2016)
Andrew Reynolds, Jasmin Christian Blanchette, Simon Cruanes, Cesare Tinelli. Model Finding for Recursive Functions in SMT. IJCAR 2016 - 8th International Joint Conference on Automated Reasoning, Jun 2016, Coimbra, Portugal. ⟨10.1007/978-3-319-40229-1_10⟩. ⟨hal-01336082⟩
158 Consultations
167 Téléchargements
