Identifying Representative Users in Matrix Factorization-based Recommender Systems: Application to Solving the Content-less New Item Cold-start Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Intelligent Information Systems Année : 2016
Matrix factorization has proven to be one of the most accurate recom- mendation approaches. However, it faces one major shortcoming: the latent fea- tures that result from the factorization are not directly interpretable. Providing interpretation for these features is important not only to help explain the recom- mendations presented to users, but also to understand the underlying relations between the users and the items. This paper consists of 2 contributions. First, we propose to automatically interpret features as users, referred to as representative users. This interpretation relies on the study of the matrices that result from the factorization and on their link with the original rating matrix. Such an interpretation is not only performed automatically, as it does not require any human expertise, but it also helps to explain the recommendations. The second proposition of this paper is to exploit this interpretation to alleviate the content-less new item cold-start problem. The experiments conducted on several benchmark datasets confirm that the features discovered by a Non-Negative Matrix Factorization can be interpreted as users and that representative users are a reliable source of information that allows to accurately estimate ratings on new items. They are thus a promising way to solve the new item cold-start problem.
Fichier non déposé
hal-01336300 , version 1 (22-06-2016)
Marharyta Aleksandrova, Armelle Brun, Anne Boyer, Oleg Chertov. Identifying Representative Users in Matrix Factorization-based Recommender Systems: Application to Solving the Content-less New Item Cold-start Problem. Journal of Intelligent Information Systems, 2016, 48 (2), pp.365-397. ⟨10.1007/s10844-016-0418-3⟩. ⟨hal-01336300⟩
772 Consultations
0 Téléchargements
